Question about Hunter "Lexus" Traditional 52" Ceiling Fan "Black" w/ three Blade Choices
I have a sears "designer series" ceiling fan which has 2 speeds like normal, so I installed a dimmer, but the motor hums. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • AsshoIe Jul 13, 2010
    The fan still moves at the same speed on the highest setting as it did with on/off switch. It can vary the speeds. The only problem is that it hums. It is not in the noise-sentitive area. I just need to know if this fan is suitable for dimmer switch. My other problem is that one of the blades is badly bent and wobbles too much on medium speed range, but wobbles a little on highest speed. How do I replace the blade iron?
  • 6,826 Answers
The motor will hum if it is underpowered by the dimmer switch.
In fact it should hum at 60 Hz, the frequency of AC power in the U.S.
There really isn't anything wrong with what you did, except
most people put the dimmer on the lights and not the motor unless by
mistake.
Hope this clarifies things.
Posted on Jul 13, 2010
    I want to know if it is suitable for this fan.
  • Duane Wong
    Duane Wong Jul 13, 2010
    In practice it should work, that if you put less amps to the motor through a dimmer switch that it will slow it down or speed it up infinitely.
    Are you just getting a humming sound but it's not moving at all? Or does it move faster or slower through a series of speeds?
    Do you want it to be infinitely adjustable in this way?
Ceiling fan hums as soon as power is applied. construction grade fans .
Is there a switch on the wall supplying power to the fan? If it is a light dimmer switch the fan will hum loudly. Make sure the switch is a ceiling fan speed control switch. If you have a fan and light combo and only one switch / hot lead you will need to install a simple on/off toggle switch.
Mar 14, 2014 | Computers & Internet
I have 2 Hunter ceiling fans and the wall switch has 2 knobs which you push to click on or off.......after you click on...you can turn the knob and increase or decrease the fan speed. You can click on both...
Hello .. you should be able to find a replacement for your fan control at any building supply store, a home depot type store. Look or ask for a variable speed fan control. This is slightly different from a normal liight dimmer . You might also look for a replacement knob before replacing the whole switch, or matbe getting a replacement just to replace the knob ..
Jun 18, 2010 | Hunter Ceiling Fan Control Switch
We have two seperate light switches. One is a dimmer. The fan is currently working off of the dimmer switch. Is this because the red wire should have been hooked up with the power source (Black wire)...
The dimmer normally controls a light which is 100 watts or so. The dimmer is rated for only so much load.It is only a fire hazard if the dimmer is overloaded by a fan and light that draws alot of current. Some fans have a light and 2 pull chains,one for fan speed and another for the light itself.There is usually only one power source for the fan.If it is a split design,then the light can be run off the dimmer,and the fan off of the switch. If you want to vary the fan speed with the dimmer ,make sure it is rated for at least the load rating.
Apr 26, 2010 | Hunter (25417) Ceiling Fan
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
Humming noise
If you are using a dimmer switch to operate the fan instead of a fan speed controller, that is the cause of the humming. If you turn down the speed to the lowest setting and the hum gets louder, then your controller needs to be replaced.
Sep 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
I just purchased and installed a Hampton Bay palm beach 48' ceiling fan (close to ceiling mount)Problem is when turned on I hear an annoying hummmmmmmmmmmm, more of a hum at high speed and it graduates...
You have a rotating dimmer switch on the wall to control speed right? If so, it is the wrong type switch. The missed matched switch will cause the humming. Use a regular on/off switch and control speed with the pull string
Apr 29, 2009 | Madison Avenue 04317 Hampton Bay Ceiling...
Altura 68" ceiling fan noisy
TAKE THE DARN THING BACK, IT SHOULD NOT MAKE ANY NOISE.
Jan 13, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton bay fan noise
The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
HOWEVER...
The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
* If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
* If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
* Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
* Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
I hope this helps you! If you have any other questions, or need clarification, please ask!
Jun 14, 2008 | Hampton Bay 24002 Ceiling Fan
Celing fan making noise, how to oil
HOWEVER...
Apr 30, 2008 | Hampton Bay 24002 Ceiling Fan
Quit working
first turn it off, then rotate the fan, half turn and try to turn if on again. if it start running again you have a faulty motor, and need to replace it. or if the problem continue, try replacing the switch in the wall.
Nov 24, 2007 | Hunter 23852 Classic Original Ceiling Fan
Hunter "Lexus" Traditional 52" Ceiling Fan "Black" w/ three Blade Choices Logo
47 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
