Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
It smells like paint when its on?
This problem has lasted for two years - i think the smell got in there when we installed and were renovating - but i need to figure out how to get it out - it doesn't happen with the heating side???
I have an LG gas dryer, lately when the dryer has finished my clothes has a burning smell to them. I recently painted and noticed the smell at that time. Though the paint smell is gone the burnt smell has...
Mark, My name is Hal and having trouble understanding where you painted. Did you paint the inside of the drum? Or did you paint the house interior?
If you painted the inside of the drum did you use a high temperature paint? If not, that could be your problem since the dryer does get very hot inside and it could be melting your paint.
Aug 06, 2011 | LG DLG5988 Gas Dryer
I have an electric flat top range, it's about 4 years old and just within the last few days every time I use the oven it omits a very strong chemical odor. I have not been using it because it does not...
Hi, If it is the paint that is chipping on the bottom of the oven then that is where you are getting the smell. That paint is actually very important to keeping the heat inside the oven and not letting the actual cavity itself from getting too hot. I hate to say it but you will probably end up having to replace the oven. You can get a second opinion from a local servicer to give a definit yes or no. but from the sounds of it that is what you will have to do. Sorry, hope this helps.
Jan 12, 2011 | Maytag MER5775Q Electric Kitchen Range
I bought a Sunbeam Heating Pad (Ultraheat) last year which I just took it out of the box last night. It is brand new, not used until last night and it smell like it was burning. I instantly unplugged it....
Sorry to read about your problem, I hope this helps you out.
i think from sitting in the box for a year, the material can smell, form its first time usage.
I suggest you put the pad on or in a baking dish on the stove..plug in and see if the smell burns off. I think it will.
if not return to Sunbeam (800) 435-1250
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Sunbeam 722 Heater
Ventless gas heater smells like kerosene
It is posible that your heater is burning fumes from paint, varnish or stain and some times carpet cleaners or other household cleaners. I work for a utility company. We get called to homes for a lighter fluid/kerosene smell quit often. Most of the time it is from the fumes burning off on a standing pilot gas oven. The odor collects in the oven and is released in the customers face when they open the oven door. This will happen with any open flame appliance when exposed to these fumes.
Feb 05, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Charmglow Ventless Wall heater stinks - Literally!
some suggestions that may help: a sulfer type smell is the additive in the natural gas, kind of like eggs. if this is your smell, you have a gas leak. if any other propellents like hair spray, furniture polish, air fresheners are nearby, the vapors are burned by the stove and you can smell those, as well as a fine white powder building up on the stove. if a paint smell, then check to see if the back wall of the stove paint is burning away. if so, you can speed the process with a small hand held torch used for plumbing. when the paint is gone, the smell is gone. good luck.
Dec 30, 2008 | Heating & Cooling
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Rav 4 1999 5 sp. slipping when accelerating
hi sounds like your screen or tranny filter needs to be changed check maintaince records last time done what you can do while vehicle is running pull tranny stick smell fluid does smell a little like paint thinner what color is it is light pink to brown needs to be changed
Sep 12, 2008 | 1999 Toyota RAV4
Stink Smell from Electric Clothes Dryer/Fuse Box
this should be quite easy to solve.remove the circuit breaker and sniff it. if it is the same smell you are getting when the dryer is running that is your problem.have an elecrtician check and replace with correct value.the dryer is most probably running on an overloaded circuit.
Jan 07, 2008 | Dryers
Heater smells
I think that it is a cheap heater and the smell is the metal paint is burning .away I think that you should give it a little more time bec after that paint goes away it wont smell any more.
Dec 29, 2007 | Reddy Heater-30-55,000 BTU Variable
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
56 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
