Question about Sony SPP-A2780 Cordless Phone System
Can't register new handset SPP - H273
The dum instructions PGM, INTERCOM, enter system ID, PGM again.
Tried pressing 2, 6 & erase at same time to put handset in test mode. Went through this long process; however, instructions were for the A2720 need the ones for the A2780
  • 146 Answers
SOURCE: no intercom connection between handsets
Here is a link to the uniden manual link and an excerpt from the manual section which deals with your problem :
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
The handset doesn't
communicate with other
handsets.
• De-register the handset (see "De-register the Handset" on page 32) and register the handset
(see "Register the Handset" on page 68).
• Make sure that you have registered all handsets.
An extra handset can't join
the conversation.
• Make sure there are not 2 handsets already using the 3-way conference feature.
The handset or the base can't
join the conversation
• Make sure that another handset or base is in privacy mode.
To register a TCX805 handset, simply place it in the main base.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD.
When R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to
the base. If R e g i s t r a t i o n f a i l e d . appears, please try these steps again.
To register a ELX500, TCX440, or TCX400 handset, follow the steps below:
1) Disconnect the AC adapter from the main base.
2) While pressing down flash/find hs, reconnect the AC adapter.
3) On the handset, press and hold # until you hear a beep.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD. When
R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to the base. If
Posted on Jan 16, 2008
SOURCE: MSPP-A2780 will not connect to the base
My new phone finally DID register when I followed the procedure WITH THE 2ND (ORIGINAL) HANDSET NEAR THE BASE.
Posted on Feb 18, 2008
SOURCE: Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Posted on Jun 23, 2008
  • 79 Answers
SOURCE: how to use intercom between two handsets
For models with 2 or more
handsets included
Making an intercom call
1 Press {INTERCOM}
2 To page the base unit, press {0}.
To page another handset, enter its
extension number ({1} – {4}).
The destination unit beeps for up to 1
minute. Someone else can answer the other unit and talk to you.
3 To end the intercom call, press {OFF}.
Posted on Aug 24, 2008
SOURCE: Sony SPP-A2780 2.4GHz CORDLESS PHONE... Problem:
how do I register my cordless sony phone
Posted on Oct 22, 2008
Hand phone rings approx. every 20 min.
Contact your carrier, they will assist in setting this up for you.
Apr 28, 2014 | Sony SPP H273 Cordless Expansion Handset...
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONS
Here is the answer! Press the INTERCOM button one time.
The INTERCOM display will show on the screen.
Use the UP or DOWN arrow button to select the HANDSET number.
Press the MENU/SELECT button to ring the HANDSET selected.
Press the END button when done talking
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
I just got this phone VTech 5881. I plugged it in and have tried to register the handset. I can't. It has someone else's name in it. what should I do?
First, deregister all handsets:
Step 1: At the base, press MENU, scroll to BASE SETTINGS, then press OK.
Step 2: Using the base dialpad, enter * * 3 3 5 7 8 2
Step 3: Re-register each system handset:
At the base, press MENU, scroll to DISPLAY BASE-ID, then press OK. The 15-digit base ID number will be displayed.
Step 4: Using the handset dialpad, enter the base ID number. Repeat the registration procedure for each system handset. Each handset is assigned a number in the order of registration
Dec 13, 2008 | Lands Phones
The hand set unit has a lot of static.
Try DeRegistering and ReRegistering the handset:
From the base system:
  • Press Menu
  • Scroll to System Settings - press select
  • Enter System PIN - press select (default pin is 0000)
  • Scroll to Mobile Deregustration - press ok
  • Scroll to the corresponding intercom # - press select
Then turn on Handset:
  • Please Register will be displayed - press ok or Register
  • Enter System PIN - press ok
At Base:
  • Press Menu
Back to the Handset:
  • When Select Intercom Number is displayed, select the number - press ok
Hope this helps!
Nov 11, 2008 | Siemens Gigaset 8825 Cordless Phone
SORRY TO BE REDUNDANT BUT DID YOU HAVE PHONE IN STAND BY AND NEAR BASE.
THEN PRESS PGM
THEN INTERCOM
THE SCREEN SHOULD SAY ENTER SYSTEM ID
ENTER THE 10 DIGITS SYSTEM ID ( THIS NUMBER IS ON A STICKER ON THE BOTTOM OF THE BASE PHONE)
THEN PRESS PGM.
MAKE SURE YOU ARE PUTTING THE CORRECT ID NUMBER IN THE PHONE
I HOPE THIS HELPS
Jan 29, 2008 | Sony SPP-A2780 Cordless Phone System
Spp n1000
1.Press PGM. The Talk/Batt Low lamp flashes.
2. Press SPEED DIAL.
3. Press one of the dialing keys (0-9) to store phone number. You will hear confirmation beep.
4. Enter the phone number you want to store (up to 20 digits)
5. Press PGM. You will hear a long confirmation beep and number is stored. Tall/Batt Low lamp goes off.
Do not allow more than 20 between each step of the procedure. If you enter a wrong number, press PGM and start over.
Jan 20, 2008 | Sony SPP N1000 Cordless Phone
ATT 5840 Base reset code/procedure
document.write(parent.prscreen) Try this to get it working. Relocate the handset(s) closer to the main base.
Check for any lights on the base including charge, intercom, and channel lights (if applicable to the model).
Re-cradle the handset on the base for 15 seconds. Lift the handset and press PHONE.
Unplug the AC adapter from the main base unit and take out the battery from the handset. Leave it unplugged for 15 seconds. Plug the handset battery in and re-cradle the handset. Plug back the AC adapter in and wait for 15 seconds.
Try to de-register the handsets by following the steps below:
1. Using the soft keys on the base located below the base screen, press MENU
2. Press the down arrow once until BASE SETTINGS is highlighted.
3. Press the OK soft key.
4. On the base, press MUTE 3 times and FLASH twice. This will
deregister the unit.
Below are steps on how to re-register the handsets:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Other products that use the 5.8GHz band can interfere with the use of this phone. These products or equipments include: radio towers, page towers, cellular Phones, other 5.8GHz cordless phones, intercoms, or monitors. If any of these are in the area, they may interfere with the performance of the phone. Try relocating the phone.
Video displays, Televisions or Personal Computers can cause
interference on the phone if it is plugged in electrically with one of this equipment (typically on a power strip or extension cord). Please relocate the phone to an AC outlet without any other major appliance plugged in.
You can also relocate the base to another room.
Relocate the phone out of the kitchen area. Appliances may cause interference.
If the charge light does not remain on, clean the handset and base charging contacts using a pencil eraser. If it comes on after cleaning the contacts, you may need to charge the unit for 10 hours.
Make sure that the AC power cord is securely plugged into the base. If unsuccessful, plug the unit into a different known working outlet or turn on the switch on the power strip.
Dec 19, 2007 | AT&T 5840 5.8GHz...
Sony SPP-A2780  Cordless Phone System Logo
75 people viewed this question
Top Sony Lands Phones Experts
Marvin
Marvin
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
