Question about Genie Company Genie PowerLift Excelerator 8 Ft Door Extension Kit, 36326R
Garage door wont close completely - Genie Company Genie PowerLift Excelerator 8 Ft Door Extension Kit, 36326R
    Scholar:
  • 143 Answers
There are a couple of reasons this might happen. First make sure it closes by hand all the way, if not there is something wrong with the door that will need attention first. If it does close then hook the opener back up. On the opener rail at the end by your header there is a little magnetic relay that is wired to the motor head. This can be moved farther up or down the rail. This sensor tells the opener when to stop in the downward direction. Loosen the set screw and move it toward the header 1/2 inch or so and try to lower the door. Do not move it too much at one time and if you do the door will hit the ground and come back up. Thanks BB
Posted on Sep 03, 2010
5 Suggested Answers
jessee007
  • 310 Answers
SOURCE: door will not close
the eyes are a little bit out of adjustment
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 09, 2008
  • 3197 Answers
SOURCE: garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Posted on Aug 04, 2009
  • 244 Answers
SOURCE: garage door will not shut with remotes.
Align sensors or replace,
Posted on Dec 29, 2009
  • 3197 Answers
SOURCE: Hi, I have a Lynx 455
Check the sensors in the doorway. Sounds like they may be misaligned. They need to be pointing at one another to work properly.
Posted on Sep 28, 2010
How do i fix my garage opener? It attempts to close but reverses itself and does not close completely
It is not closing completely because either something is in the way of the door closing properly or the mechanism controlling the safety feature is malfunctioning.
Sep 29, 2016 | Sears Craftsman LiftMaster Chamberlain...
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
I have a Digidoor garage door that closes halfway and the opens again however when you apply a little pressure to the door the door closes completely The entire shaft was cleaned and lubricated but still...
There probably is a dent along the shaft either in the remaining region or the already occupied region. You should open it completely and verify that the shaft is uniform. There could also be a deformed roll in the part of the door that enters the vertical part of the shaft around the time the door stops closing.
Nov 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hello, my garage door wont closely completely, it stops about 2 inches from the ground. so, i just need to know how to reset it thanks
On the motor there is an open close knob. Turn it toward close until it closes completly.
Aug 24, 2011 | Garden
Garage door wont close - acts like there is an object in the way. If is detach the door from the sliding unit, the door closes easily. If I try running the slider down without the door attached, it stops...
It sounds like the sun may be shining on and causing problems with the door sensors. Try using the cardboard tube from a roll of toilet tissue on the receiving sensor.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Open and closing problems w/ garage door
First adjust the down limit setting. There is two white screws on the side of the opener. The one that says down needs to be turned to the less side. One full revolution of screw adjusts approx. two inches. Turn it down until the door does not close all of the way and the slightly turn it up until the door closes all of the way with stight pressure on the door. Next there are two blue screws on the back of the opener. they should be on the five setting on both the up and down screws.
Mar 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not close
Jan 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Genie Company Genie PowerLift Excelerator 8 Ft Door Extension Kit, 36326R Logo
511 people viewed this question
Top Genie Company Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
