Question about Soleus PH310R03DB Portable Air Conditioner
E4 error Soleus PH5 series portable Heat Pump Air Conditioner
Unit works for about a hour and then it reads E4, and does not cool. If I turn unit off and back on it cools again.
SOURCE: Maytag NMPEB08F2A Portable Air Conditioner
I have the same problem w/ a window unit - fedders unit under the Maytag brand. No idea how to fix it, but would be great to get some info on this.
Posted on Aug 05, 2007
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
SOURCE: cooling
Is the fan blowing. If so your compressor is probably the source. If the fan isn't blowing you might have a bad fan motor
Posted on Jun 20, 2008
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
  • 36 Answers
SOURCE: Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
Posted on May 27, 2010
Eurodib Portable AC E4 Error code
Make sure the condenser and evaporator fins are clean, and that there are the condensate drain hole or hose is not clogged. Also, check the blower or fan bearings to make sure they turn freely without grinding or noticeable sideways slop.
Jul 03, 2017 | Heating & Cooling
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Where is the fuse located on my soleus air conditioner lx-140 house unit. I want to replace it.
PDF]download manual - SoleusAir
www.soleusair.com/Manuals/2013%20Manuals/.../PH4-13R-01_Manual...
Thank you for choosing a Soleus Air Portable Air Conditioner with Heat Pump ... owner's manual will provide you with valuable information necessary for the
Aug 17, 2015 | Soleus Heating & Cooling
Getting an E4 Code and the air is not as cool as the temperature reading indicates. How to fix?
I think it is low on gas. You will have to call the repairman on this one. If it is real old, just replace it.
Jun 09, 2015 | Heating & Cooling
How to fix E4 error
check the water tank flipper if broke it will directly cause the unit to not function and the E4 message will apper on the display screen.
May 26, 2014 | Soleus LX-140 Portable Air Conditioner
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Code E3
check the evaporator drain make sure it's empty
Jul 29, 2012 | Soleus Ph5-13r-35d Portable Air...
Ac unit keeps reading fl or full. every 2-3 hours. auto clean button drains out about 1/4 a gallon of water and then stops draining. turn back on ac & repeat process every 2-3 hours. I have tried...
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
Soleus PH310R03DB Portable Air Conditioner Logo
422 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
