Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
How do you transfer new refrigerant to tank - Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
    President:
  • 180 Answers
Connect fill hose ( Black hose with 2/1'' quick connector located at near the tank strip) to source tank (New R134a refrigeration tank) & make up side down. switch on the machine power switch. Press main menu key then keep pressing up or down arrow key till appear "Tank Refil" on the display screen. with "Tank refill" on screen press YES key. the message will change to ''Checking source tank" for few second then start filling refrigerant to ISV tank. press NO key to exit when you want to stop filling.
Hope this will help you, Good lucl & vote for my solution!
Posted on Jul 14, 2010
I have a 90 F250 4x4 with dual gas tanks. The rear tank needed a new pump so had it replaced. Now, I got a new problem, the back tank pumped fuel into the front tank to a point gas flowed out the filler...
the diverter valve that shuts the flow off to fuel tank, and transferes over to other tank is bad. here is a picture of it--1990 f250 valve. selector_small.jpg
Nov 14, 2010 | 1990 Ford F250
BMW316 E36 1994. fuel does not appear to be transfering form left side of tank to right hand side. New pump fitted. Problem still occuring . How is the fuel supposed to transfer between the 2 tank...
Connection will be dropped out of plastic pipe inside tank!
Empty the tank, under the rear seat removed the fuel pump and next to the
hand into !empty! tank and can feel the relief pipe and where it fell! Simply plug in back
Jun 21, 2010 | 1994 BMW 3 Series
1989 lesabre fuel tank replacement help?
Yes, you will need to swap everthing over to the new tank. The new tank will just have holes for the components
Jan 21, 2010 | 1997 Buick LeSabre
How refill my tank of freon 134 in my machine ?
Fix low side coupler to R134a refrigerant sorce (new refrigerant tank with up side down & tank valve open) tank.Open low side manifold valve & close high side manifold valve.press tank re-fill or recover botton & fill as you want.NOTE: Max.cap.50 LBS or 23 KG.
Jan 21, 2010 | Measuring Tools & Sensors
2007 Chev. 3500 flatbed deisel trucks w/Dual Tanks
Unless they have a seperate switches for tanks and gauges they equallize to give you a overall reading.
Sep 09, 2009 | 2007 Chevrolet Silverado 3500HD New Cars
I have an 85 Ford E350 chassis motorhome that won't switch to the rear gas tank. When the you flip the selector switch at the dash, you can hear a click from the transfer switch on the frame. The rear tank...
You should be able to hear the pump in the tank running. If you don't check the fuel pump relay. If you hear the pump running then the line/filter could be plugged. The white relay is the tank selector relay, the green relay is the fuel pump relay. If the green relay is bad you will have a bad time getting the replacement. The new relays from the dealer and parts stores are all 5 pin. The green relay is a 4 pin.
Also your genset probably has a pump that pulls from that tank on its own.
Jun 26, 2009 | 1985 Ford Econoline
JCD2389GES Side by side
yep need to order an new water tank for the ref
Apr 12, 2008 | Jenn-Air JCD2389G Side by Side...
Water dispencer
Hi. This is normal and there is nothing wrong with your refrigerator. Whenever you replace the water filter on any refrigerator, you must run a couple gallons of water thru the water dispenser until all the air from the new water filter is out. Use a large container to do this. The water will not stop when you pull a cup away because the water valves used on refrigerators are so weak it will not close until it has pressure on both sides of it. If you don't get the air out, the air from your new water filter can go to the ice maker and stop ice production. So flush the air out of your new water filter. The water you are drinking from your drink dispenser may not be healthy. It may contain a small plastic floating substance. This is part of the plastic that the water tank is made of. The chemicals in the water do this. You will have this problem even with a new water filter because the water tank is after the water filter. You have to replace the Water Tank. The water tank is located in the refrigerator section on the bottom back wall. I sell low cost new designed Water Tanks on Ebay as username: themackshack. Good Luck, Mack
Mar 18, 2008 | Whirlpool ED2FHEXN Side by Side...
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
322 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
