Question about Jada Toys 1963 Cadillac Series G2 1:18 Scale Die Cast Vehicle with Scarface Figure
I have a 63 caddilac with a 390 and a 4GC how do i ajust the idle all i see is a fast idle ajustment and the idle air and fuel mixture screws
    New Friend:
You will have to ajust the fast Idel down an then for the Idle air an fuel screws up till it Idels even. If it does not Idle even you have went to low on the fast idel. Only adjust the screws a quarter turn at a time till you get it to purrr like a kitten. I also have one of those an had the same problem.Luckily my father is a master mec. for caddys,ford,chevy,dodge,etc.He can pretty much listen to any car made ever imports an fix whatever is wrong. Hes 74 years old an thats all he has ever done is work an build old cars.
Posted on Jul 15, 2014
Ajust idle on 2002 FXDL
Hi Anonymous, on the right hand side of the carburator there is an idle adjusting screw with a spring behind it, turn screw clockwise to increase idle counter clockwise to decrease idle. There is also an air/fuel mixture screw inside a carb body lug that may or may not be plugged with an aluminum cap that's about 3/16" thick. This cap can be drilled out to acess the air/fuel mixture screw. Turning screw clockwise will lean out mixture and lower idle, turning screw counter clockwise will richen mixture and raise idle. You need to balance the two adjusting screws to obtain an idle of 950-1000 RPM then back out air/fuel mixture screw 1/4 turn, snap throttle to confirm responce, you may continue to back out air/fuel mixture screw untill desired throttle responce is achieved, if you see black smoke coming out of exhaust you have gone to far and need to turn screw back in 1/8 turn at a time. Good luck.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 04, 2013 | 2002 Harley Davidson FXDL Dyna Low Rider
Esco chainsaw model 162
The adjuster screws on a chainsaw carb are fuel screws,not air screws, so by unscrewing them anti clockwise will richen the mixture, there are normally three screws, an engine idle screw, this will operate against the throttle spindle, a screw marked L, this will adjust the fuel mixture from idle to half throttle including acceleration, and a screw marked H, this will ajust the fuel mixture from half throttle to full revs, as this will increase the maximum revs it is very importent not to exceed the manufacturers no load speeds, so a engine tacometer should be used to check this, over speeding can seriously damage the engine.
May 06, 2013 | Garden
How to ajust carb on a harley 1100 sportster need to know settings bike is jumps in 1 st & 2 nd gear after 2 nd runs good
Hi Deeprun5, on the right hand side of the carburator there is an idle adjusting screw with a spring behind it, turn screw clockwise to increase idle counter clockwise to decrease idle. There is also an air/fuel mixture screw inside a carb body lug that may or may not be plugged with an aluminum cap that's about 3/16" thick. This cap can be drilled out to acess the air/fuel mixture screw. Turning screw clockwise will lean out mixture and lower idle, turning screw counter clockwise will richen mixture and raise idle. You need to balance the two adjusting screws to obtain an idle of 950-1000 RPM then back out air/fuel mixture screw 1/4 turn, snap throttle to confirm responce, you may continue to back out air/fuel mixture screw untill desired throttle responce is achieved, if you see black smoke coming out of exhaust you have gone to far and need to turn screw back in 1/8 turn at a time, final adjustment should be made with the engine at normal operating temperature. Good luck.
Aug 20, 2011 | Harley Davidson XLH 1000 Sportster...
My craftsman chainsaw is pretty new, and it isn't starting properly. When it does start, it has a tendency to cut out during use. I adjusted the idle time, a few times, cleaned the air filter, and checked...
There will be three screws on the carb, the tick over screw, a L screw which ajust the mixture from idle to half throttle, ans a H screw which adjusts the fuel running speed, they are both fuel screws not air screws, start with a basic settinf of one and a half turns on each from closed, with the saw idling gently screw the L screw in, the revs will start to increse as the mixture weakens off, it will reach a point where it starts to die, at this point start unscrewing the L screw, the revs will increse again and then start to die because its too rich, now turn it in 10 minutes on a clock face, check that it revs cleanly,adjust the idle screw so as the chain does not rotate around the bar, the H screw controls the max rpm, this should be set with a rev counter, it should not exceed 12500rpm
Apr 21, 2011 | Garden
I just put on a new rebuilt carburator on my 460 v8 1987 xlt 250 ford truck 4 WH. drive. its a motorcraft stock holley. I cant seem to find a way to ajust it. Wont run smooth or idle? It was set up for...
You have two setting screws on front of carb, You start off by adjusting all the way to the left, Then back off 3/4 turn to both setting screws, Then you have to set your air fuel mixture by just slowly turn your setting clock wise do so until vibration go away. Sorry there is no easy way to explain, Good luck to you,
Apr 03, 2011 | Ford F-250 Cars & Trucks
Engine idling rpm is erratic when cold. low power during startup. fuel mixture is very rich.
ajust your mixture screw on your carb turn it in fully then unturn two and half turns that should get your mixture ok you mat need to fine ajust later
Nov 11, 2009 | 1996 Mitsubishi Eclipse
Idles fast exhaust gets red nhot
better ajust choke or turn down idle screw before u burn engine-must have air passin by cylinders--may also be an internal problem with carbs like dirt etc-buy a manual for troubleshootin
Sep 17, 2009 | Yamaha Alba Motorcycles
1980 Trans am original 4.9 engine. I messed up fuel and air screw
Screw each one in all they way, and then back them out two and a half times, then start it up and then ajust each until it runs smooth.
May 12, 2009 | 1979 Pontiac Firebird
Ryobi lawn hornet mk2
Change your spark plug
If the fuel oil mixture is too oily it will foul the spark plug and no cleaning will get it right.
If there is a lot of oil in the crankcase it may foul the new spark plug so another new one is needed
Aug 10, 2008 | Electrical Supplies
Revs go up and down while idling
fuel and air mixtures need to be ajusted
there are to screws nextt each other just play around with them you will get it running great
Aug 04, 2008 | 1992 Isuzu Rodeo
Jada Toys 1963 Cadillac Series G2 1:18 Scale Die Cast Vehicle with Scarface Figure Logo
108 people viewed this question
Top Jada Toys Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Jada Toys Toy Expert? Answer questions, earn points and help others
