Emerson LC320EMX LCD color patterns
I thought my remote needed the batteries changed because the volume down button was not functioning, so I changed the batteries to new ones and tried it again, same thing, I have had problems with remotes before so I thought I would open the remote and check where the bottom of the buttons meet the connectors on the circuit board, they looked clean, then the **** happened, I saw where a button was supposed to go but was left out for my particular model, I pressed it to see what it done, it took me to another screen which showed the model number and manufacturer, a few second later it started a color pattern loop where the whole screen flashes colors like on this video, the colors may not look right in the video, if they dont the colors are as follows:
Red to a few seconds, Green for a few seconds, Blue for a few seconds, white for a few seconds, Black for a few seconds, a white/black gradient for a few seconds and then another white/black gradient for a few seconds before cycling through it all again in a loop, I tried using the usb port to reinstall firmware to no avail.. Anyone know what I can do to fix it? It does has a service terminal (USB flash drive port)
This video shows it rotating through the colors
http://www.youtube.com/watch?v=ITXgt227dzY
  • Matt Casdorph
    Matt Casdorph Oct 01, 2011
    I actually fixed it sometime back, I bought a RCA universal remote that had arrow keys, after programming it to the TV I hit all the buttons until it came out of the loop, it was the left arrow key.. I dont know why the arrow keys on the emerson remote didn't do it.. And to dlustberg01 yeah support wants you to send it back and get it "repaired", who know how much they would charge... But all is good now.
Did you find a solution, I have the same problem with my Emerson TV. Same color pattern loop. Tech support was no help and TV is just 3 months out of warranty.
Posted on Dec 04, 2010
  • Matt Casdorph
    Matt Casdorph Dec 04, 2010
    Yes, what I did was buy a cheap universal remote (I also have a vizio remote that works too), one that has a lot of buttons including up, down, left and right arrow keys (I believe hitting the left arrow key is what took it back out to the diagnostic menu where you can press power to exit it), I know it sounds crazy but It works and saved me alot of money rather than getting a new one or having it repaired.. Here are the codes and remotes that work with the TV..
    RCA RCU600M not sure what the code was.. (if I can get it, i'll tell you)
    Vizio xru9m: TV code for LC320EMX is 1172
Press the up button on the factory remote then release then press the down button. then just hit the power button to get out of the menu. worked for my EMERSON lc320emxf.
Posted on Oct 01, 2011
My TV has powered off and will not turn on. whats up
if the batteries are good in the remote and it wont turn on using the buttons on the tv, check the mains fuse in the plug failing that the power supply could be faulty and in need of repair
Feb 19, 2015 | Emerson LC320EMX 32 in. LCD HDTV
How do I set my remote-control to my Emerson,LC320EMX hdtv 32inch
Google the model number with "manual" or as last resort contact Emerson customer service.
Dec 17, 2012 | Emerson LC320EM8 32 in. LCD TV
I fell asleep on my Emerson LC320EMX 32 hdtv remote; when I awoke, the tv was flashing ONLY colors (red, black,blue,white)...Now, How do I get it out of that mode....I was told its stuck in set-mode ?
I had this problem with the LC320EMX, after extensive searching on the internet, I found a solution. The TV has entered some kind of test pattern, to escape from the flashing color test pattern do the following:
While the screen is changing from red,green,Blue,White, & Black, and is Unresposive, Take your factory remote, Press the up arrow, then the down arrow, then (ON THE TV) press the power button. Turn the set back on and it should be functioning properly. (BTW: the set gets into this test pattern if you press too many buttons on the remote, or if you use a universal remote with the wrong code)
May 31, 2012 | Emerson LC320EM8 32 in. LCD TV
Emerson lc320emx remote sensor not working
Some advice--the sensor if bad requires the set to be opened and will be on a tiny board--whole board would have to be replaced as this company does not sell single parts (most now do not).
I would have the remote tested---most shops have a tester where remote is pointed at it---buttons (any or all) pressed to check it.
Some digital cameras when the remote is pointed at them will have a flash when the remote is used---
Either the remote or the sensor or something near the sensor is the problem.
If remote held very close to sensor and works----sensor is the problem most of the time.
Apr 16, 2012 | Emerson LC320EMX 32 in. LCD HDTV
I lost the code book to my universal remote
Try to GOOGLE the exact model number for the Remote with the word manual after it.
Mar 12, 2012 | Emerson LC320EMX 32 in. LCD HDTV
I have a new Emerson LC320EMX 32" TV. The suddenly stopped working right. It will not turn off. There is no picture, only colored screens. When you change the channel it just shows a different color...
Your TV is still in the factory test mode. To remove from the tech service mode try this.To exit the service mode, grab the original remote. Press the cursor left followed by the cursor right button. Now press the off button on the remote or on the TV itself. Hope this helps. Thanks for asking and show a few hands of support!
Nov 11, 2010 | Emerson LC320EM8 32 in. LCD TV
Sylvania 27" derailed by Emerson universal remote
CHECK YOUR TV MANUAL FOR REMOTE INSTRUCTIONS IF STILL HAVING PROBLEMS CALL EMERSON AND TALK TO THEM ABOUT YOUR PROBLEM
Aug 25, 2008 | Orion STV2763 27" TV
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
621 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
