Question about Cyberhome CH-DVD 300 DVD Player
It just says loading and never works
Is it hooked up wrong or ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
I had this problem. sorry, but this player is dieing.
Posted on Jul 14, 2010
If hooked up wrong will it blow a fuse or not work anymore
What did you hook-up wrong, hope it wasn't the battery? If you hooked up the battery wrong, not sure what kind of damage might have been done?If some other component, which one?
Any electrical component that doesn't work, check wiring diagram, check voltage and ground for that system.
What is year--make--model?
Nov 10, 2016 | Cars & Trucks
Hooked up LED lights front and rear turn signals with brake light. Brake lights and rear turn signals worked until I hooked up front turn signals. Now rear turn signals not working but brake light is
Usually when you install LEDs, because of the difference in the voltage draw, to work correctly you need to install a "load equalizer".
Do the rear turn signals light, but not flash?
If so, that's most likely the problem.
Mar 31, 2013 | 2009 Harley Davidson FLHR Road King
When i load a purchased cd everything works fine except there isnt any sound. The radio works great
Does it work for regular CD's?
If you have an amplified system, you may have the wrong wires hooked up for the "remote".
Swap power antenna and remote blue wires and it should fix the problem.
Feb 28, 2011 | Car Audio & Video
If i wired my stereo amp up wrong could it cause the stereo to stop working just by attempting to turn the volume up
Define wrong...You need to hook the speakers up to the amp so there is a load for the amp to transfer the power to. If you have the polarity reversed it won't mess up anything but it will sound weird.
Jan 31, 2011 | Kenwood Audio Players & Recorders
I have an old intermatic (1983) freeze guard that I am trying to wire into my pump timers. 4 wires are 2 for load and 2 for line in. 2 orange and 2 red. Which color is the load and which color is the line...
To determine which set of wires are the LINE wires from the freeze guard:
First turn the thermostat2_bing.gif to the HIGH setting (so that it turns the load OFF), then pick a set of wires (say the red wires) and connect them to 240 volts. Turn the thermostat to the LOW setting (so that it turns the load ON). If you picked the right set you will hear the relay kick in _and_ the other (orange) set of wires will then have 240 volts on them.
If you picked the wrong set of wires to start, you won't damage anything because all you will be doing is energizing the load side of the relay contacts. In which case, nothing will happen after you turn the thermostat to the LOW setting (to make it turn the load ON), and no voltage will e on the other set of wires either.
What it boils down to is just hook it up. If you connect it wrong it won't damage anything, it just won't work. If it doesn't work swap the wires.
May 10, 2010 | Electrical Supplies
I have a frigidaire front load washer that doesnt work right
I would like to give a brief description of how it works, what could go wrong and the intangibles: These new fangled washers use artificial intelligence.
The brain has sensors and uses logic to control the wash sequence. The brain can tell if the hose are hooked backwards, the load is too large, the wrong amount of soap, The wrong soap, long fill, and long drain. To get the most out of the machine it is best to use the right soap and wash reasonable loads. When you start the wash the water temps and water level are monitored by the brain, any abnormality like a slow fill or wrong water temp is gonna be picked up by sensors. If all of that turns out to be correctly connected and should be functioning normal then either you have a failed component or a wiring problem. In that case the brain will give a fault code of some sort.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
I hooked up my hp pro webcam and it wont't work with messenger live. What am I doing wrong?
is it acutally showing up under control panel scanner and cameras?
the driver is probably not loaded meaning not camera. otherwise MSN should come on with Video Call.
Jul 24, 2009 | Logitech Webcam
E70 ERROR SIGN
Great news that worked!! I had other issues with my washer and had a repair man come and fix it, when he left I started washing and that's when the E70 showed up uhh he hooked the hoses up wrong.. Thanks a bunch
Mar 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
J/l 500/1 amp
I'd lay you odds that you are driving the wrong speaker impedence and that you may have damaged the amp. This is most often true when you improperly bridge into the wrong load. If you are lucky enough to not have damaged the unit then you need to get your speaker load right at once before you fry it, if you do indeed have the wrong speaker load (too much).
Jul 28, 2007 | Jl Audio 500/1 Car Audio Amplifier
Cyberhome CH-DVD 300 DVD Player Logo
62 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
