Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Lost partion I am using a windows (Xp-sp2). I have drives C, d, e and F in my computer and all of them are FAT32 system. I used partion magic to resize my drives C and F so that free space in F could be allotted C drive for increasing the size of C. Partion magic completed all its tasks and when I started the computer it shows modified capacity for all drives but drives d,e,f are shown as not formated (raw disk) in windows. When I see these drives from partion magic it shows the drives as inactive but shows the drive contain data. I am not able to access any of my d, e, and F drives. Please advise me how do i recover my d,e and f drives.
  • 88 Answers
You have to format drives d, e and f. Go to my computer;then right click on the raw drive (d,for this instance); click format, disk capacity and allocation sizes will be shown; select either quick format or full format. You may also compress the disk. Do the same for drives E and F. Formatting may take a few minutes depending on the size of the drive.Hope this helps.
Posted on Apr 21, 2008
I have to recover fat32 partion with OS & data
Dear user,
Pl Check your format your c: drive or D: drive.
another way you connect your hard disk to another working coputer and pl check your hard drive data by drive.
Regards,
Ravindra Shah
Jun 01, 2009 | Computers & Internet
Whenever i creat partions with help of cd suddenly power is put offf.... then there is no response...
hi..there...what kind program for create partions that you use? and what operating system that installed for your computer?
if you use XP..maybe you can try "partions magic 8" is very easy..just insert this cd to cd drive and you can follow the instruction that showing at the desktop...good luck
Feb 02, 2009 | Computers & Internet
Partition problem
In my humble opinion, the best option is to install a second (blank or larger) drive. Install some recovery software such as "easy recovery pro" or something that will be able to read files from a filesystem that has had the partition table written over. Start with trying to scan using FAT32, and in failing that, try NTFS. Restore the data to the second drive, format the first and partition as required. Copy the data back to the first drive to the partitions that you specified, and erase the data from the second drive. A free option may be pandora recovery, available at http://www.pandorarecovery.com/features/
Jan 20, 2009 | Microsoft Windows XP Professional
Partition Problem
Yuou must backup the data of d:\ in another harddrive or volume before doing this backup your data in another volume and then merge the data you can even copy the sectors from partion magic .Data can be recovered by using data recovery softwares.
Partition parameter
From the data you provided, the D drive is deleted and is newly created. But it is not yet formatted. So the data is virtually deleted. Why I said virtually is because, the data is still there on the drive physically and you can recover it using third party tools like OO disk recovery tool. That is why partition magic is still showing data on it.
And it is also obvious that the task which Partition Magic started (splitting drives) is not finished properly. That is why K partition is incorrectly formatted. It is natural that it asks format of D drive because D drive belongs to no file type and it must be of FAT32 or NTFS or other file system.
The solution for your problem is try recovering your data on D drive using disk recovery tools. Then format it using FAT32 or NTFS. Format K drive also in FAT32 or NTFS. Use either partition magic or Computer Management. Since already PM caused problems on your computer, try computer management. It is safe.
RAW file system
RAW file system is typical of an unformatted hard drive and is the default state for most new retail drives because the manufacturers won't know which operating system their customers are going to put on the drive or use it in conjunction with.
Most operating system installations come with utilities to partion and and format new drives see fdisk from MSDOS (specifically versions 5 and higher) And MS Windows 3.1 through 95,98 and ME which all used the FAT32 file system as default and would partition and format during installation. Windows NT similarly would partition and format the drive during install to the NTFS system, as do all versions of Windows XP.
if you are not installing a new OS but setting the drive as a slave to a currently installed drive then you can use a program like Partition Magic or similar to detect the installed drive and partition / format it tou your requirements
Oct 08, 2008 | Computers & Internet
Formatting
NTFS if you are using Windows XP since this allows you to have support for larger drivers and faster read and writing capability
FAT system is actually for older drivers that have smaller capacity as well as for thumb drives.
FAT32 is a file system to use if you are planning on having dual OS meaning running Windows 98 and Windows XP at the same time so that you can switch files or share files.
Generally FAT32 is only used now for this reason if that will not be done then NTFS is the best one to go with
Aug 21, 2008 | Intel Motherboard
Corrupted Windows
hi
if u want to repair window xp
insert your cd in rom.
then restart your pc.press del key or any other key to enter your bios.set advanced option first boot rom.save your settings.then press any key to boot from cd.
after approx 5 min .
when ask u to press enter.
if u want repair xp to its recent condition press r and if u want new winxp press esc key.
then press F8 then u show your partion of drive.
press D to del selected partition.
after del all partion press c to create partion and set as u wish to manage your partition. then in c partition press enter to format the partition using quick fat32 or ntfs.
then follow the instruction .
Mar 21, 2008 | Computers & Internet
WINDOWS XP SERVICEPACK TWO INS NOT WORKING
try to change your ram b4 you install sp2.
Mar 15, 2008 | Intel D865GVHZ Motherboard
Installing Windows XP alongside Vista
First you want to install xp and then only you want install vista because higher version will not take lower version.
Feb 26, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
104 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
