Question about Panasonic Audio Players & Recorders
I need an illustration to install a drive belt for Panasonic SL-N15 model. This is a linear tracking turntable. I purchased a belt from a website - it is not a Panasonic, but they claim it will fit my turntable - I think it's too big, but since I don't know how to install it, I can't be sure. I need a picture or diagram showing where to place the belt exactly under the platter.
That's right.
Here are some in-depth instructions.
Turntable-belts generally go from the spindle motor to the underside of the platter. The platter, or table tray, is the metallic structure which supports the record. After taking the platter off the turntable, a pretty self-explanatory process, look for the only large, circular "lip" on the platter's backside and wrap your belt around it. Make sure the band is flat, not twisted. Put the platter back in its original place and, working through one of the holes in the platter, pull the turntable belt to the far side of the spindle motor.
I hope this helps.
Posted on Jan 03, 2011
    Guru:
  • 256 Answers
There should not be any special way to install this belt. All turntablebelts go directly from the spindle motor to the table tray.
Posted on Jul 13, 2010
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
Where can I purchase a new rubber belt to drive my Servo Automatic turntable SL-B210 Ths is not an electronic belt
Here is a link for Technics Turntable replacement belts...just scroll way down the page for your SL-B210 belt listing $10.00. Hopes this helps.
http://www.turntablebasics.com/belts/technics.html
Oct 28, 2009 | Technics SL-1210 Turntable
Suggested lubricant for Technic SL-5 linear tracking tonearm
technics used special grease for lots of their products, any good quality grease will do but use sparingly
Apr 07, 2009 | Audio Players & Recorders
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
How do I change belt on a Technics linear SL -H350 turntable
http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
Jan 03, 2009 | Panasonic Technics SL-DZ1200 Turntable
Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Nov 15, 2008 | Technics SL-1210 Turntable
Problem with technics SL-L20 linear tracking turntable
Not sure what your question is? Linear tracking turntables also have an assortment of gears and pulleys which make it function correctly. Sometimes the drive belt will break, other times, the gears will crack. You will have to open her up, and take a look inside to see if there are any components which are damaged. There may also be grease applied to the gears, which might also be preventing it from moving properly.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jul 22, 2008 | Panasonic Audio Players & Recorders
Technics SL-DZ 1200
More than likely the traverse assembly needs to be replaced. Unfortunately, this is not easy, as Panasonic does not sell this assembly complete. YOu will have to purchase each part individually, and this in itself is not an easy task. Only an service tech knowledgeable with this unit will be able to help you out with this. Unfortunately, I cannot refer you to anyone in Taiwan.
Panasonic service is useless all over the world. I have never heard of a good repair story about Panasonic, so it's good that they didn't attempt the repair. Go with a independent reputable local service center.
Your always welcomed to ship it to us here in NY. But it wont' be cheap, and there could be more damage to the unit during transit. Just a suggestion though, if you can't find anyone in your area.
- Davis
DJ Pro Audio
www.djproaudio.com
www.djprolab.com
Jul 12, 2008 | Technics SL-DZ1200 Turntable
Technics sl-ql 15 linear tracking T/Table
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
May 30, 2008 | Technics SL-BD22 Turntable
510 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
