Question about Dolphin Maytronics Advantage
My Dolphin Diagnostic pool cleaner stopped working.
The tranformer power swith can be turned on and off, but thecleaner does not respond.
    President:
  • Dolphin Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 13, 2010
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
Dolphin diagnostic motor replacement
May be the circuit board - There is an on-line group called Circuit Board Medics who can test and repair the board.
Jun 22, 2012 | Dolphin Maytronics Diagnostic Robot...
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
WHERE CAN I FIND I REPLACEMENT FOR THE FUSE CAP FOR THE DOLPHIN DIAGNOSTIC RD-DC?
Use the contact feature on our website and include your dolphin model number and the serial number in your inquiry. We will respond with the current part pricing. For help with the serial number location, look here...
Nov 10, 2009 | Dolphin Maytronics Diagnostic Robot...
Motor stopped working on the dolphin diagnostic pool cleaner
It can be the motor, the cable, the power supply or any combination of those items. If you are in need or parts or want to send it in for repair, contact us using the dolphin service form or contact form found on www.arrowpools.net.
Oct 02, 2009 | Pool & Spa
Stops after a few feet
It can be in the power supply or the motor pack. You can contact us using the dolphin service form at www.arrowpools.net or try the manufacturer at www.maytronicsus.com.
Jul 16, 2009 | Smart Pool Inc Dolphin Diagnostic...
My dolphin diagnostic cleaner for my below ground pool, just stopped after years. I went to turn it on yesterday and there is power to the power box as the light goes on, but the unit is not moving. I am...
If your unit has a fuse it will be on the back side of the power supply. If the light on the power supply switch is on, it will not be the fuse though.
Try turning the cleaner upside down on the deck and connect it as you otherwise would. Power it up and it should go through a self test process that takes about 40 seconds to complete. If it turns the tracks in both direction with and without the impeller turning, it is fine and will likley start working in the pool again.
If not, contact us through www.arrowpools.net and click on the FAQ and then Dolphin cleaner catagory. You can also use the Dolphin Serice button for information about sending it in for repair.
Jul 03, 2009 | Dolphin Maytronics Advantage
Circuit board inside power supply is bad. I need a replacement
You'll need a replacement board. You'll need model and serial numbers off of the cleaner itslef to help identify which power supply and therefore what PCB is needed to replace yours. Try contacting our service center at www.arrowmotor.net and click the contact button in the upper right corner.
Jun 13, 2009 | Smart Pool Inc Dolphin Diagnostic...
Dolphin Maytronics  Advantage Logo
621 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Marvin
Marvin
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
