Question about Samsung HCM4215W 42" Rear Projection Television
I changed the bulb of my Samsung tv and it is still blinking lamp. How do I fix it?
  • Samsung Master
  • 8,457 Answers
U here a alot of clikcking,turn power on to tv?Yes,than the Ballast board also dead,need it be replacing.The Ballast board,help to ignite the bulb.
Posted on Jul 13, 2010
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a Samsung 56" DLP tv. was watching and it went off. light on lower front blinks 3 times, when attempt to turn on. Could it be the lamp light?
Does these LED indicator lights that blinks?It is one of the LED light said lamp or bulb?The tv been used alots,and it at lest 2 years.U have not change the tv lamp or bulb to this tv?Change it,life of the lamp it over.
May 03, 2010 | Samsung HLP5067W Television
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Light bulb not working after colorwheel replaced
Same thing happened to me (By jschmidbauer on Jan 14, 2010). How did you fix it????
Jan 14, 2010 | Samsung - Projection TV replacement lamp...
I just replaced the DLP Lamp and housing on a 50' Samsung DLP tv.
CK your Fans make sure they are running or set will not come on.also if you can solder resolder power supply board.
Apr 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
Samsung HCM4215W 42" Rear Projection Television Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
