Question about Crosley Traveler Turntable
I have the crosley cr 50 bt. It quit spinning. It is not very old. It is not the belt and there is power to it because the radio is able to be turned on just not the turntable.
  • 104 Answers
SOURCE: The turntable for Crosley Radio CR66 will not work.
http://www.archive.org/details/Turntable_Belt_Installation
Posted on Feb 22, 2009
mydogisk
  • 50 Answers
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Posted on Apr 10, 2009
SOURCE: Turntable does not turn
Try this - GENTLY move the phono arm to the RIGHT until you hear a click Tof course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
If it doesn't work, you can check the belt by removing the tiny clip at the center post and gently lift the turntable platform/tray to peek at the motor and belt underneath. The pulley is on the right at the 2 o'clock position, the belt should be in contact with it.
Posted on Aug 07, 2009
  • 69 Answers
SOURCE: Crosley CR66 turntable not turning, belt is fine - motor?
frozen motor maybe or blown interal fusesmaybe,try manualy spinig platter to try an maybe free it up
Posted on Aug 08, 2009
  • 84 Answers
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
Schematic for placing belt on CR-711
Have a look on YouTube there are several good videos on replacing belts, otherwise you might have to end up paying for a manual just to fit the belt. You can try the Crosley website they might have a free PDF of the manual.
Jan 05, 2016 | Crosley Audio Players & Recorders
Where can I find a replacement power switch?
Power switches are safety components that can only be replaced by manufacturer approved parts. Contact Crosley for where you can get approved parts.
Nov 24, 2015 | Crosley Entertainer CR-79 Turntable, CD,...
I have a Crosley 3 in 1 turntable (not sure of the model but I'll include a photo). The turntable spins fine if it hasn't been in use for a while. But after I start to play a record, the turntable will...
Crosley Turntable Belt Replacement Video from Crosley Radio on Vimeo
Yes. Please contact Crosley Radio at 1-866-CROSLEY for assistance on replacement parts.
It sounds like the turntable belt has stretched . Replqacemnet belt can be purchased from Crosley. The number is above.
Jun 02, 2014 | Audio Players & Recorders
How can i slow down the turn table on a crosley cr 66 multiplayer with no control speed and it don't work pulling the arm to the right I tried that not helpful
The problem is in the motor of the turntable, the regulator is not putting out the correct voltage to the motor, and the circuit is often built into the motor making it impossible to service. The only option is motor replacement.
Mar 12, 2012 | Crosley Entertainer CR-79 Turntable, CD,...
The turntable belt wasn't atached and i need th know how to put it back on.
Good day. Lift the rubber mat off the platter and notice the two rather large holes in the plater. Put your thumb and forefinger through the holes and pull the platter off the turntable unit. Place the platter upside down and notice the inner rim which holds the belt. Place the new belt around the inner rim and replace the platter onto the unit. Now, with tweesers, working through one of the large holes, pull the belt onto the spindle motor. Once on, spin the platter by hand and make sure the belt does not slip off. Hope this helps
Mar 30, 2011 | Crosley Entertainer CR-79 Turntable, CD,...
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Getting the turnable to come on
some platters will not begin to spin until the tonearm is lifted up from the rest and over to where the record is, then it starts spinning.
alternately the belt may have come off.
will provide general info on how to put it back on.
Jan 11, 2009 | Crosley CR248 Turntable
Crosley cr 78 cd record player plays to fast.
Dec 12, 2008 | Crosley Conductor CR73 Turntable
Crosley Traveler Turntable Logo
220 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
