Question about iLO (2 GB) MP3 Player
My ilo doesn't turn on when the usb cable is connected to it
Whenever I don't have the USB cable NOT connected to the ilo mp3 player it turns on..But..when I connect the USB cable to it,it doesn't turn on !
Despite the fact that I already had the cd installed in my computer !!!
How in the world do I solve this ?!?
  • mysterius Apr 24, 2008
    same thing
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Problem with mp3 player
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Jan 06, 2009 | Jwin MP3 Player
Tip
Connecting an Eclipse MP3 Player to a Computer
Many people have found that their computers do not recognize the Eclipse mp3 Player, even after connecting with a USB cable. I had the same problem but discovered that the problem lies with the cables themselves. I have several USB 2.0 5-position cables that fit the Eclipse USB port perfectly, but only ONE of them actually works - the cable that came with the player itself. If you've lost this cable, you may be in trouble.
Attached is a screen-grab of the type of USB plug and port involved. You don't see them around very much anymore, and I have no further advice if your player doesn't have a USB port of this shape.
on Feb 01, 2015 | Eclipse Audio Players & Recorders
Tip
ILo Mp3 Player Help is Here
iLO Mp3 Player
"Flash Error"
on Sep 13, 2008 | iLO (2 GB) MP3 Player
Flash Error!
iLO Mp3 Player
"Flash Error"
-Tha Mp3 Doctor
Sep 27, 2008 | iLO (2 GB) MP3 Player
Solving my problem
Sep 24, 2008 | iLO (2 GB) MP3 Player
Have problems with my ILO
Sep 23, 2008 | iLO (2 GB) MP3 Player
The mac and the mp3 player
You must have an ilo player or any related one which will synchronise all your songs and show your prescene
Jun 23, 2008 | iLO (2 GB) MP3 Player
I can use ILO only when i am connect to my computer
Reformat and use only (important) MP3. files no WAV WMA or any of it MP3 only hope it works (and reformat)
Sep 10, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player won't turn on
Ok, SOME MP3/4 Players indeed charge from the USB port, albeit slowly... usually tho there comes a charger that plugs into the "Mains" and then plugs into the USB socket on the Player.. Sometimes if the Battery goes really "Flat" the USB port is unable to supplu enough "Current" sucessfully charge it up. (Hence the need for wall charger) IF it was entirely Via USB it would take many hours, I would at least think overnite. Hope that hepls.
Jul 30, 2007 | iLO (2 GB) MP3 Player
Need help with ilo mp3 player
May 09, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
L Pfaff
L Pfaff
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
