Question about Dishwashers
Soap dispenser on bosch dishwasher won't close. How do I fix it?
  • dishyissue Jan 08, 2009
    The dispenser does not close per your comment above.
    how do i fix the problem?
When you slide the dispeser door closed push down on it on the left side it will then latch. This dw is new, or new to you isn't it?
Repost if this doesnt solve your problem and I'll help if I can....I work on Bosch
Posted on Apr 20, 2008
SOURCE: Dishsoap stays in soap dispenser
Same thing happened to us. We noticed that it happened if the soap was left sitting before starting the washer. Since then, we immediately start the washer after putting soap in it and the problem appears to have gone away.
So much for the delayed start features, but at least the soap doesn't stick anymore.
good luck!
Posted on Jan 03, 2008
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
  • 311 Answers
SOURCE: Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Posted on Nov 28, 2008
  • 132 Answers
SOURCE: The soap dispenser on my bosch dishwasher doesn't open
it is agood manual solution but if you want to rea ly fix that there is {an electrical order reach at suitable time to open the dispenser it come from electronic circuit to elecronic lock which catch the
dispenser so one of those parts may be fualty
Posted on Jun 09, 2009
  • 135 Answers
SOURCE: soap dispenser does not close
Make sure the dial is at the start positon and not in between on some other setting.
Posted on Sep 05, 2009
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
Our dishwasher's soap dispenser's lid won't stay put when we close it. Is there anything we can do to fix it?
Most often this is a replacement part. check HERE they should have it for your model.
Jun 10, 2011 | Bosch Dishwashers
Soap dispenser not working
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 07, 2011 | Bosch Dishwashers
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap Dispenser Cover
This soap dispenser is the same as Bosch. Source lid and blue clip, this will rectify, but make sure v spring is re-fit correctly. PW.
Dec 24, 2007 | Siemens 24 in. SE64A630GB Built-In...
Dishwashers Logo
319 people viewed this question
Top Dishwashers Experts
