Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
2 year old stainless steel dishwasher making weird sounds
My 2 year old Jenn-Air dishwasher is making a rattling and gurgling sound that's coming from the base of the washer. I unloaded all the dishes just to be sure I did not load something improperly. Did not take the washer thru a full cycle, but stopped it for fear of damaging it more. Any solutions?
  • 1,998 Answers
Are u hearing any metal grinding sounds or is it making a noise like something is breaking theres a pump located down the bottom of the unit and depending on how you wash your dishes for example if you wash them before you insert them into the dishwasher or if you put them in with food on them would consitute your next course of action if you do insert them with food on them then you would need to check the pump and the chopper area you might want to call a technician if the problem persists. hope this helps try running it through the full cycle if tere is something wrong you will get an error code
Posted on Jul 13, 2010
  • schwartzeslv Nov 05, 2010
    more than likely just a piece of hard food or even a pc. of broken glass getting chopped up in the built in chopper. Be sure to rinse dishes if not going to run right away after loading. NO big pieces of food left on plates!
My dishwasher is making these horrible screeching sounds during the wash cycle !! It's a stainless steel fridgdaire dishwasher about 5 yrs old
Open up the door, try spinning the cross fan to see if you can replicate the sounds if it does, check the fastener to see if it's either too loose or too tight, either of which can create such sounds.
Mar 17, 2013 | Dishwashers
My Jenn- Air dishwasher (2 years old) used to clean great but now it is leaving a white film on the dishes and there is often residue left in the glasses as if it is rinsing with the dirty water. I can't...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 20, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
The door sticks on the right side when opening; makes a loud unlocking sound.
level dw and adjust the front legs to fit in the opening / then mount it so it does not move . first install was inproper or uou would not be having this problem .. mm
Dec 14, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Smell in a new dishwasher
run bleach through it. if your on well water then this will happen often
Jun 22, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Heating element comes on and stays on when not even called for.
There is a stuck relay or switch somewhere.
The important thing at this point is that you get it turned off!!!
Flip the breaker if you have to, but get it off, as it is a fire hazzard like that.
You can attempt to diagnose the problem yourself if you like and we can help. You will need a multimieter hat can read Volts, amps, and ohms.
If not, disconnect power and call a pro. But whatever you do, get it off ASAP.
Jan 07, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Stainless steel is rusty/blotchy
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
Jan 02, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
601 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
