Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
I have a Macintosh. When I tried to plug in speakers the hole for the plug wasn't deep enough. Pushed it in harder and got the speakers to work. When I unplugged them my computer no longer had sound without the speakers.
  • Apple Expert
  • 481 Answers
The audio-out jack on the MacBook Pro is a dual-purpose jack: it works with both electrical and optical connectors. (You may occasionally notice a red light leaking out the port—that is the optical circuit.) Because of its construction, it is stiffer than usual when you are inserting a standard electrical headphone jack and binds halfway in (which one could easily describe as feeling "not deep enough"). But because of its internal mechanical complications, it doesn't always reset properly when you remove the plug. This is a known problem with this model of Macintosh. Often inserting and removing the plug a few times will loosen it up enough to restore the speaker contact. If it doesn't, then a trip to an Apple Certified Repair outlet is in order.
If you google "macbook pro audio jack repair", you will find reports from hundreds of people encountering this problem. The actual repair involves a logic board swapout, and can be very costly. My advice would be to get a quote for this, then call Apple Customer Relations and propose that it should be done free for you because it is a clearly documented widespread product defect. The people at Customer Relations are surprisingly liberal and I have had excellent results going this route.
Posted on Jul 14, 2010
Why am I unable to hear sounds through my head phones Galaxy S5
Check the headphone connector for lint.
Restart your phone.
Is there sound from the external speaker without headphones plugged in?
Is your phone playing sound through the external speaker with the headphones plugged in, or is there no sound at all?
Do you have any third party apps such as SoundAbout installed on your Samsung Galaxy S5?
Dec 23, 2014 | Samsung Galaxy S5
Tail light wires
I just solved my identical problem on a 2003 750 ACE. The four way connection in back of the license plate housing was pushed inside the back of the housing with the left turn signal wire crimped a little between the housing and the fender (probably at the factory)., It wasn't crimped enough to break the wire, but just enough to apparently short out the circuit. The clear vinyl cover was melted just a little bit where the wire was crimped but it didn't look like there was enough damage to cause a short. I stripped the clear vinyl cover off, taped it with electrical tape, and made sure that all of the wires were pushed inside the back of the housing. Everything works, plus the 15 amp fuse doesn't blow anymore. Hope this helps.
Rick.
Aug 19, 2012 | Honda VT 750 CD Shadow A.C.E. Deluxe...
Soap gets clotted is soap dispenser. Dishes greasy and dirty after cycle.
Hi, the soap is clotting because there isn't enough water being sprayed around inside. The water spray washes the soap out of the dish, if all is working well. My machine had the same problem. I had sufficient water level, but the spray head wasn't spinning very well. I found the end-most hole in the spray bar to be plugged. It is the end hole that provides a jet that makes the head spin. I cleaned a bunch of debris out of the hole and the machine started working and cleaning like it was new.
Jun 26, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
My bissell proheat turbo 2x hand tools will dispense solution but not water.
  • Fixed it! The check valve on the bottom of the bladder wasn't going deep enough into the recepticle on the base of the unit; the valve wasn't opening, and the pump was sucking from a dead end. (It WOULD pull soap from the small tank, but not the main bladder reservoir.) I cut a 3/4" piece of a disposable ball-point pen cap, to ride over the rod in the center of the recepticle. Long enough to push the valve open, but short enough that the tank assembly sat down on the base. If the rod is too long, it will push the whole tank up, and break the vacuum seal at the forward edge. Evidently this thing was designed to a tight tolerance, and just a little aging/distortion of the plastic reservoir base was just enough to keep the valve from being pushed open!
  • Jan 29, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
    CD player on computer has locked it self and I don't know how to unlock. I've used a straightened paper clip inserted in the tiny hole to open but now that doesn't work either.
    This hole MUST work :) it will not pop out the tray like it does after clicking button.
    You have to poke this hole GENTLY, deep while deeply you push then more will the tray come out. When it comes enough to grab it with fingers then you will pull it easly.
    Check video below to see how.
    Leave rate if I helped you, thanks!!
    Cheers,
    Mike
    May 09, 2010 | Computers & Internet
    Does not power up
    Reset button on rear in a hole or the control unit has to be in the grooves on the rear of the fryer and pushed all the way down. there is a safety switch in the groove on the control unit.
    Hope that works.
    Apr 01, 2009 | Bravetti K4305H Deep Fryer
    2004 s60 volvo wont start
    Petrol, diesel engine?
    Adding more information may help to get an answer.
    Dec 02, 2017 | 2004 Volvo S60
    Hi, I have a humminbird wide one deep m, it came with the boat I recently brought. The first two trips out fishing it worked fine, then for some reason it just stopped working. Why would it do this? Much...
    the base that the unit plugs into has a plug in for the transducer and one for the power. make sure that the power plug is pushed in far enough on the mount so the unit gets power. then tighten up the screw that holds the two in place.
    Dec 01, 2008 | Perko Combination Masthead & All Round...
    Ge dp16 cordset
    Ge customer service at 1-800-267-0516 needs to hear from enough requests and GE will refill DP16 (item#227366)power cords in stock at GE for Fryer model #168952. "There made to order with enough requests or complaints"-Cust. Serv.
    So with this info, everyone please call with item number above model 168952 and state you need a new DP16.
    Hope this is helpful!
    Chuck-NJ
    Jul 21, 2008 | GE 168952 Deep Fryer
    Bravetti Deep Fryer Model F1053B Not getting Power anymore
    Hey guys I fixed my problem...yay. All I did was to push a red button which I beleive is a resset button on the back of the on/off button part. It ain't visible but if you look in the holes of the screws that hold this part together (they are far down in the hole) one of them hides a small red button. Push it down with a toothpick or anything small enough to fit the hole and you're done. Plug it back and it works.
    Apr 13, 2008 | Bravetti EP4305FS Deep Fryer
    Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
    57 people viewed this question
    Top Apple Computers & Internet Experts
    marty morrison
    marty morrison
    Paul Carew
    Martin Buck
    Martin Buck
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
