Question about KLH DAV-5022 DVD Player
WON'T OPEN TO LOAD DVD.
I CAN'T GET THE DVD TRAY TO OPEN TO LEAD A DVD.
JUST WON'T RESPONT TO OPENONG THE TRAY
I am having the same problem - any help will be greatly appreciated!
Posted on Dec 03, 2010
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Dvd tray won't open
The tray needs a new motor with a new pulley that does not slip on its shaft and get a new belt too.
It is easy to pull the dvd tray unit out of a GO VIDEO DVD+VCR machine to replace the motor with new pulley on it and the belt should be renewed too.The motor NOW may run only to push out the tray but it will not pull it in to LOAD the DVD or CD.
This is what I found after troble-shooting the function.
From Jim, and I need the same things. Can anyone tell me where I might buy those idems? lemsojim@gmail.com
Oct 07, 2011 | GoVideo Go Video DVD/VCR Combo
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
Will not open the DVD tray.
if your dvd tray is not open you need a one inch pin or needle into hole..the hole right side .....then your dvd tray open
Feb 01, 2008 | Samsung DVD-HR720 (80 GB)
CD tray does not open when Button Pressed
does the tray open when you right click on the drive icon in "My Computer" and select "eject"?
Oct 25, 2006 | Sony DRU-810A DVD RW Dual Layer Burner
KLH DAV-5022 DVD Player Logo
83 people viewed this question
Top KLH Televison & Video Experts
Steven Wander
Steven Wander
josepovedaca
Level 1 Expert
ray gallant
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
