Question about Garmin nuvi 350 GPS Receiver
When i turn it on it loks like i am connected to computer
I have to unplug the power cord and start it over and so far that clears the connection sign
  • 63 Answers
It sounds like you are using a power cable from a different device. first make sure you plug into the cradle and not the unit. Second make sure you use a Garmin power cable.
If you use a third party cable the unit will go into PC mode. To buy a cable visit GPSCity.com
Posted on Jul 13, 2010
How to install a power supply
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Unplug all electronic cords connected to the computer. At no time during the installation should any cords be connected to the computer. Remove the screws holding the computer cover case, and remove the cover case. Locate the computer power supply box, which looks like a large box out of which a bundle of wires run and connects to the power cord jack on the outside of the computer case. Unplug the power cables from the internal devices connected to it. Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember--write it down if you need to--what devices will need reconnecting to the new power supply when you finish the installation. Unscrew the power supply from the inside of the computer case and remove it. Check the original power supply's red voltage switch for the correct setting. It should read 120 or 240 if you live within the United States. Confirm this setting as the correct voltage setting for your power outlets. Make sure your new power supply gets set to the correct voltage setting before you install it. If it cannot be set to the correct voltage, do not proceed with the installation or you may damage your computer. Return the new power supply and buy one that is compatible with the voltage requirements. Install the new power supply, reattach the screws that will hold it in the proper place inside the computer. Reattach the power cables that come from the new power supply to the devices that were connected to the old power supply. Make sure all of these connections are firmly in place before you turn the computer back on. Reattach the computer power cables and all the cords connected to the computer during normal operation, but do not close the computer case yet. Keep your hands clear of the inside of the computer case as you attach power cords and peripheral devices. Turn the computer on and observe the performance of the computer without touching anything inside. Do all the computer fans function normally? Does the computer operate as well as or better than before? If you feel that the computer behaves normally and you do not encounter any problems, turn the computer off, remove all the power cords and peripheral cables once more, and close the computer case. Then reattach the power cords and peripheral cables and begin using the computer. Check for errors if you encountered any problems starting the computer or if it would not start at all, unplug all the power cords and computer cables connected to the computer and look inside. Make sure that you connected all the correct power cables inside the computer securely and did not miss any. If you have confirmed this and the computer still doesn't start or operate normally, call your computer manufacturer or a professional computer repair shop for assistance completing the installation http://www.youtube.com/watch?v=xvClS_M-09o&feature=watch_response_rev watch video http://www.youtube.com/watch?v=s0udZ0Ky4Pk Hope this helps.
Jan 03, 2013 | Computers & Internet
Can't install power supply
Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember write it down if you need to what devices will need reconnecting to the new power supply when you finish the installation.
If you have confirmed this and the computer still doesn't start or operate normally, call your computer manufacturer or a professional computer repair shop for assistance completing the installation.
Most power supply units will fit
Like everything else in our high-tech world, power supplies come in myriad sizes and shapes
you should check all the electrical connections before you make a decision and make sure they are the same as the ones that you will need to run your computer also
Check the measurements inside the frame to make absolutely sure it will fit,
http://www.youtube.com/watch?v=mKw0bij8CDs
Hope this helps
Nov 13, 2012 | Insignia D400a PC Desktop
Power supply
Hope this helps
Nov 13, 2012 | Insignia D300a PC Desktop
Do not know how to connect power supply
watch video
hope this helps
Oct 10, 2012 | Computers & Internet
Remove versa 6060 bios password
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 13, 2012 | NEC Versa 6060 Notebook
Lennovo g570 bios cmos not responding for enabling password
Aug 11, 2012 | Lenovo G570 Notebook
Lenovo t410 reset bios password
Aug 06, 2012 | Intel Biostar P4TSE-D2 865 Chipset...
Lenovo desktop 3282 beeps twice then 5 times and goes no further
Aug 01, 2012 | Lenovo Computers & Internet
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
Unable to connect to internet through Linksys WRT160N router. Can unplug it and internet is fine. Tried power cycling the modem and router. Linksys comes up with all lights flashing and will not...
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
Dec 30, 2010 | Linksys WRT160N Wireless Router
Garmin nuvi 350 GPS Receiver Logo
42 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
