Question about IBM ThinkPad T43 Notebook
I can't turn the mic off and I get feedback when the speakers are on
    Problem Solver:
  • 16 Answers
Pls open the control to change it.
Find the best IBM battery replacement here...
Posted on Jul 13, 2010
Feedback 3-4 mtres from speakers
Feedback is caused by having the volume up too high or being too close to the speakers. Turn mic down a bit, feedback goes away.
Better speakers and mic will help.
Sep 11, 2014 | AKG WMS 40 Mini Vocal Set Handheld...
Excessive feedback
On mic? On guitar? Take top frequencies off EQ, point mic away from speakers. Use decent dynamic mic or feedback resistant condenser such as Sennheiser e865. Try Behringer feedback shark
Feb 06, 2014 | Music
My subwoover is giving me large feedback, like high pitched noises
lower the mic volume or don't be so close to the your speakers when using the mic. or turn off your mic. thanks and have a nice day.
Apr 30, 2011 | Cyber Acoustics CA3602 2 Speakers
Hi im using the carlsbro gd 4000 in a 3 piece rock and roll band we are using an oldmike shure c606 and we cant get any volume out of the mike and its distorting the vocals we dont know whether the p.a.s...
Proper placement of mics versus the speakers of a PAS is important to avoid feedback. Your speakers need to be toward the audience from where the mic is. If the mic can "hear" the speakers you will likely have feedback. The mic should work even though it is a consumer grade mic.
WORD OF CAUTION: There are a LOT of fake SM58 microphones being sold... even on Ebay... SOME are fairly high quality and others are not.
Mar 31, 2011 | Music
On my Berhinger pmp 5000 powered mixer the mic trim pots seem very touchy.There is almost nothing on them until they are almost at maximum at which point you get feedback issues.How can I check to see if...
When using the trim with mics such as SM58's, etc. the trims often wind up at about 3 o'clock in normal use. You set the trims by pressing the PFL buttons down and setting the level using the led display histogram so that at maximum level of talking/singing the display never goes clear up to clipping.
IF you have feedback, then you have issues of mic location and speaker location. The critical point of feedback is far too critical to set with the trim controls.
Your main speakers should be toward the audience from the mics, not so the mics can "hear" the main speakers.
Monitor speakers are ALWAYS a problem with feedback... performers want more monitor, but depending on the acoustics of a stage, reflection from the back can get into the mics or the mics may not be directional enough... SIngers that choose to hold the mic and wave it around are a soundman's nightmare! They let the mic point toward a monitor and away goes the feedback.
The PMP5000 has a lot of power.
While your at it, PLEASE read my tip on FIXYA about PMP mixers regarding the hazard of using Speakon to 1/4 inch speaker cables... ESSENTIALLY never allow the barrel of channel "A" output 1/4 inch to be grounded as it, instead of the tip of the jack is the HOT lead !!!! This isn't in the user manual... I fix these things and discovered this hazard from the schematics.
Nov 23, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Turn up mic level and system begins to howl
Make sure the speakers are forward of the mic's. If the speakers are in back the mic's will pick them up and feedback. Keep the mic's to the rear of the speakers and away by at least five feet.
If you can't meet this requirement, then you will need to use SPECIAL feedback suppression equipment.
Jun 30, 2010 | Fender Passport Deluxe 500watt Sound...
How should I place the tie mic
Typically you want to wear the mic 6 to 8 inches below your chin clipped to the lapel area. It seems in this case it has more to do with EQ and speaker placement. If you can stand behind the speakers while using the mic. The sound bouncing back and forth between the mic and the speaker is what causes feedback. Also try setting the mic channels EQ with the following settings.
Turn Lows down to about 7 to 9 O'clock
Play with Mids to match actual source, but never boost above 12 O'clock
Keep highs around 10 O'clock (boosting highs increses chances of feedback.) If to muddy sounding keep highs aroun 12 but not over.
Good Luck
Oct 08, 2009 | Audio Players & Recorders
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Feedback
Assuming you have a good SWR, either ditch the power mike or the truck.
Aug 23, 2008 | Cobra Radio Communications
Feedback noise in speakers and Woofer.
hi wfj1310,
that feedback comes from the distance between the mic and the speakers only. Low the record level from the mic and make the distance bigger.
it makes feedback with any speaker, not only with woofer :-/
complements
Oct 25, 2007 | Audio Players & Recorders
IBM ThinkPad T43 Notebook Logo
50 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
