My danby DDR7009REE is only a month old, It is on, but it cycles between blowing hot air and cool air into the air, I don't remember it doing this before. It shudders quite a bit when the compressor is kicking on, and that's when the hot air comes out. I'm afraid it will overheat. There is water coming through the hose, but the humidity percentage stays about the same. Any solutions? Thanks!
SOURCE: Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
SOURCE: Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
SOURCE: Danby ddr7009ree - continuous drain won't work
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
SOURCE: My new Danby dehumidifier never shuts off
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
SOURCE: Hi Fixya:
How often does the unit run? Does the fan run when the unit is suppose to be running(as the fan pulls the air thru the filter). If every thing operates correctly and the filter is in the right location on the unit then all I can say is that you keep a clean house. Personally I only need to clean the air filter on my dehumidifier about once a summer. I wouldn't be overly concerned if it isn't getting very dirty.
