Question about Dell Latitude D620 Notebook
Cannot project movies in powerpoint
He is trying to play movies to a projector using a powerpoint presentation he has. His computer shows fine on the projector, but when he tries to play the video, it shows on his computer but not the projector. As soon as the movie is stopped, the projector will show his computer again. This used to work a couple of days ago, but system restore did not help. He tried using a different projector of his, but the same thing happened. We now think it is something wrong with the computer. We tried using different fn - f8 combinations, but to no avail. What is wrong?Dell model number: Latitude d620Toshiba projector model number: TDP-T45He is not using usb, but is using the cable with lots of pins (I don't remember the name).He is also using Office 2007 professional.
  • 1 more comment
  • photogman
    photogman Apr 20, 2008
    Thanks, I'll try that tomorrow and let you know the result.
  • photogman
    One more thing I forgot to add-
    We have logmein installed on his computer.  Whenever I connected to his computer and then we tried to play the videos, they would play.  I don't know why it would do that.
  • photogman
    As soon as I connect to his computer, it projects.
  • 4 Answers
I have encountered this same problem once in the office when i was trying to do the same thing.
The solution:
*Assuming you have windows xp*
1) make sure the projector and the laptop are connected (FN+F8), do a right click anywhere in your desktop then go to settings by default Monitor 1 would be your Lattitude D620 and Monitor 2 should be your projector, to make sure of that click on the 'identify' it should show a 1 in your laptop and a 2 on the projector
2) now select monitor 2 and select 'use this device as my primary monitor' check mark, by doing this your videos should play in your monitor but they will be a blank/black screen on the laptop (basically we are reverting the order).
Sincerely
McVerick
Posted on Dec 22, 2008
  • Dell Master
  • 1,183 Answers
Try changing the display resolution , best resoultion is to try it at 800 x 600 or 1024 x768.
Let me know if that works
Thanks
Mandeep
Posted on Apr 20, 2008
Change the codec of the movie or "avi" file. It seems that some projectors don't like specific codecs.
To change codec you need to use some type of conversion software. I use Bink and Smacker. Pretty good one!
Posted on Feb 25, 2009
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
How to insert video in the PowerPoint 2003?
Insert a movie and play it automatically
In PowerPoint 2003, you can run your movies full screen. This is a very excellent feature.
  • On the Insert menu, point to Movies and Sounds, and then click Movie from File.
  • Click the video you want to use and then click OK.
  • Tips: Always put the movie in the same folder as your PowerPoint presentation. If you later move the PowerPoint presentation to another computer, copy the movie too. Keeping your movie in the same folder as your presentation ensures the link will still work. However, you should always test the movie on a new machine just to be certain. Re-insert the movie, if necessary.
  • After you click OK, you' are promoted with a message asking how you want the movie to start in the slide show.
    I recommend choosing Automatically even if you want the movie to play when clicked- I will talk about how to set this part too. (If you choose when clicked you have to click the black box to start the movie. Because I don't like to show the black box on the slide, I do this a little differently.)
  • You should now have a small rectangle sitting on your slide.
  • Insert a movie using a file on your computer or in another location, such as a server.
  • The movie appears as a still frame on your slide.
  • The trick I use is to move that rectangle off the slide, so it is sitting next to it, but not on it. You can size it down if you like. Click the movie (that is, the rectangle) and then drag it off the slide.
    Play the movie full screen
  • Right-click the movie object (the small rectangle) and on the shortcut menu, click Edit Movie Object.
  • The Movie Options dialog box appears. Under Display Options, select the Zoom to full screen check box, and then click OK.
  • If you want your movie to play automatically when you advance to this slide, you can stop here.
Test this now to see how it workd by starting the slide show. (On the Slide Show menu, click View Show.) Advance to the slide with the movie, (best if you have the title of the movie on it). Within a couple of seconds, the movie starts to play full screen. When the movie finishes, you return to the same slide (but no unsightly box appears). Click to advance to your next slide.
Add an On Click effect to start the movie
If you prefer, you can click to start the movie. This requires one more step, setting an On Click animation effect.
1. On the Slide Show menu, click Custom Animation. The Custom Animation task pane appears on the right side of the PowerPoint window.
2. Click the movie object (the rectangle) to select it.
3. In the Custom Animation task pane, click Add Effect, point to Entrance and then click Appear.
You have added an On Click effect. The animation effect you added is the one with the Green star next to it and a gray rectangle around it. If it doesn't have a gray rectangle, click it to select it. Your Custom Animation task pane should look like the picture below (except with the name of your movie in the list).
4. The last step is to move that animation up to the top of the effects list.
To do this, make sure the animation effect is selected, and then click the Up Re-order arrow at the bottom of the Custom Animation task pane. Or simply click and drag the animation effect to the top of the effects list.
5. Your effects list should now look like this:
6. You are done. Test this to make sure it works by starting the slide show.
(On the Slide Show menu, click View Show.) When you advance to the slide with the movie, you should not see the movie. When you click the slide, the movie zooms to full screen and plays. When it finishes playing, you are returned to the same slide. Click to advance to the next slide.
Souce: How to insert a Movie (or video) into PowerPoint 2003?
Jul 06, 2010 | Microsoft Office Professional 2007 Full...
Powerpoint video won't play on screen
you can try changing your overlay settings. works with some formats. or you could use the projector as main display (toggle through fn+LCD/CRT)
Feb 10, 2009 | Epson PowerLite 50c Multimedia Projector
Powerpoint video problem
Does the videos play well in Windows Media Player? If not, it deciates that there are not proper codec installed on your computer.Try to download and install some new codec from official: http://www.microsoft.com/windows/windowsmedia/forpros/format/codecdownload.aspx. Go for codec references at: http://www.codecguide.com/
If the video plays well, please try the following methods:
Method 1.
1. Put video files and the PowerPoint presentation in a same folder.
2. Re-insert these files to PowerPoint presentation.
Method 2.
Insert -> Hyperlink, choose the video file you want to insert, and then click ok. After do this, you can click the hyperlink to view the video when present the slide show.
Method 3.
 1. Display the slide you want to insert video.
 2. Click the View menu in the menu bar, and then choose Toolbars in its child menu, later Control Toolbox to let Control Toolbox displayed. Choose More Controls which seems like hammer.
 3. In the succeeding dialog box, choose Shockwave Flash Object. Your cursor will change into a cross-hair - draw a rectangle anywhere on screen
4. Right click the inserted Shockwave Flash control, and then click Properties.
5. Click the Movie property > type the full drive path in the value column (the blank cell next to Movie), including the file name (e.g. C:a.swf) or URL (e.g. http://www.a.com/b.swf)
6. To make the Flash play automatically when the slide is displayed, set the Playing property to True;
7. Finally close the Properties window and save your presentation.
Method 4.
Convert your PowerPoint presentation to Flash use some third party presentation tools, PowerPoint to Flash converter, for instance.
BTW, the link: http://www.playsforcertain.com/tutorial.htm may help you.
Nov 04, 2008 | HP VP6121 Multimedia Projector
When i am doing presentation with microsoft power point2007
you have to have the music and movies files sent as well. try putting all the files in a folder (including the powerpoint file) and relinking the files in the powerpoint. then send the whole thing and you should have music and movies. try it on another computer if you want to make sure.
Jan 02, 2008 | Microsoft Office Professional 2007 Full...
Playing dvds
try function key with f4 or f5 or f6 or f7.
Dec 28, 2007 | Toshiba TLP S30 Multimedia Projector
Media player movie picture won't display
Yes, I have the same problem with a Dell Inspiron 700m laptop. I have never been able to show videos using two seemingly compatible devices. This is not a projector issue however, as my projector displays video DVD fine from this PC, only videos inserted into PowerPoint will not play. Using another computer it works fine. Imagine that, Dell selling two highly practical devices that are not compatible.
Nov 10, 2006 | Dell 2300MP Multimedia Projector
Dell Latitude D620 Notebook Logo
409 people viewed this question
Alun Cox
