Question about Mitsubishi VS-50605 50" Rear Projection Television
Im pretty sure the pip module in my mitsubishi vs-50605 has gone bad is it a real hard fix or is there some way i can bypass
  • 505 Answers
Yeah you can use two caps to bypass and pull out the whole pip module. You'll have to find schematics because I cannot find my documentation, if you can't find the schematic, then let me know I can dig some more.. Basically you pull out the pip module and then add in 2 10uf caps to just pump the signal back into the signal board.
heres something i found, not positive its credible but should be safe to try
pull the module out and just push the caps into the connector
if it works, then you can solder in, i usually broke off the old connector to have an easy pop in fix.
oh.. the symptom is usually a black or bad pic, but the pip looks good = bad pip module caps (too many to fix unless you really want pip)
heres your pic
i've seen it work with many diff sized caps, this says to use 4.7uf instead of the 10uf I suggested, either will prob work.
Posted on Jul 13, 2010
Rolling lines for first hour or so...
It's the one in the metal can, and you can't by-pass them. Very difficult for a layman to replace. It's to the right of the tuner, about 6x6 in size.
Aug 19, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Where is the pip board located on a Mitsubishi vs-50605?? need to know so i can replace caps please!
what is the problem with your set? I can only find a small stand up board on the signal pcboard that has anything to do with pip. I can't find anything on the mitsubishi web site that says anything about changing any caps on a pip board.
Aug 18, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs-45605
G'day mate
To all accounts it does, this can be checked by verifying that it has TWO antenna inputs. To get the PIP working, you will need to split and feed both antenna inputs. Seems to be set up this way to cater to PIP with set top boxes/convertors that have RF outputs
the 2 tuners can be spotted as the shielded assemblies with covers either side in the lower right corner of this pic. There is a mod floating around that involves bypassing the PIP to fix a fault that the set develops. This may have been done to your already.
check here for details.
Hope this helps you. A fixya rating is a great thankyou for my efforts to assist you . Cheers
regards
robotek
Sep 14, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Rear project TV problem
yes it can be fixed depending on your model number if its the VS50605 they have a kit to repair the PIP module which controls vertical sync (Rolling) or you can bypass the module to correct it but you would lose the PIP function. Let me know if you need more info.
Apr 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50707 50 in. Rear Projection...
There is a quick test you can do to determine if the problem is in your PIP module, using two 4.7uf/50v electrolytic capacitors. The PIP module plugs into two connectors on the main board. Remove the PIP module, and on connector VP on the main board (the 11 pin connector), use one cap to jumper from pin 7 to 9 (negative lead on pin 9); and use the other cap to jumper from pin 5 to 11 (negative lead on pin 11). If the PIP module is bad, you will now have video. The PIP module has surface mount capacitors that go bad. Just make sure you solder a small lentgh of wire to the capacitor leads to prevent them from shorting as they cross over each other. Just plug the wires into the socket no need to solder them.
Mar 08, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Whats a quick solution
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Projection tv
Vertical sync problem. This issue could be related to faulty capacitors on the PIP module, as the vertical sync runs through the PIP module. If you would like to know how to by pass the module to test if it is the PIP module let me know and will post the procedure.
Feb 20, 2008 | Mitsubishi VS-50605 50" Rear Projection...
My tv
This set is known for some very common problems some of which is just what you described. For a small fee, I can give you some common solutions that will take care of these and other issues. The only problem is you must know how to take things apart and put them back together without doing further damage, AND you must know how to solder /desolder components.
Dec 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50VA1 schematics or resistor ID
Perform PIP bypass (must give up PIP function) 1)remove PIP module,leave out. 2)Install 22mf/50v NP caps on bottom of PCB. Mount cap to VP pins 5 to 11. " " " " " 7 to 9. Re-check video=should be clean.
Aug 22, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
