Question about Aqua Vac Tiger Shark
The cleaner has been working fine. I cleaned the filter and put in back into the pool and it doesn't move. the water is coming out of the top and thats it.
  • 2,272 Answers
If TigerShark cannot climb pool walls: • Clean the filter. It may be clogged or too heavy from excessive debris. • Brushes may be worn. Inspect brushes and replace if worn. If TigerShark fails to pick up fine or heavy debris: • Clean the filter. It may be clogged. • An optional high velocity inlet is available from your dealer which clips on to the bottom lid. This inlet creates extra suction for lifting fine or heavy debris. This part also can be helpful if unit becomes routinely stuck on a raised main drain. If TigerShark starts working momentarily but then stops working: • Impeller may be clogged or jammed with debris. Check and clean if necessary • Brush rollers or drive tracks are stuck. Check for debris and clean if necessary. • TigerShark is out of the water. Put TigerShark in water and reset the power.
For getting user manual of the tiger shark. please click on the link-below:-- http://www.poolcenter.com/TigerShark_Manual.pdf
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 13, 2010
No pressure on gauge on filter pump
The same thing happened to me. So frustrating! I guess the pump that comes with the intex pool is not strong enough to do this. At least that is what I was told. So I just ended up sending that vaccum back and getting a catfish vaccum. Works great!
Jul 29, 2014 | INTEX Sand Filter Pump
Polaris won't move and seems to be nose down. The tail is moving but thats it. also when i bring the tail out of the water, it doesn;t have much water pressure shooting out.
Check the pool cleaners filter screen in the in-line filter and clean, if necessary.Clean the skimmer basket, pump basket, and pool filter. If one of these is full or clogged, it could be weighing part of the cleaner down. Check all of the hoses, connections, and swivels for leaks that could cause loss of
water pressure. Finally, make sure that your wheel RPM is set correctly (between 28-30 RPM)
Mar 02, 2011 | Polaris 380 In Ground Pool Cleaner
The wheels on my Polaris 3900 don't move. Plenty of water coming thru the thrust and the tail wags. When I move the wheels manually they all move together.
There are a couple things that you should check with these pool cleaners if the wheels are functioning properly. Check the filter screen in the in-line filter assembly and clean if necessary.Make sure that you do not have any debris or obstructions that could be halting wheel function. Even though you seem to have plenty of water, check the RPM and make sure they are between 28 and 32.
Jan 30, 2011 | Polaris 3900 Sport Pool Cleaner ()
My Polaris 380 just stop moving the pump was run and had good pressure turn one wheel they all turn freely also tail dose not move
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses,
connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Aug 03, 2010 | Polaris 380 In Ground Pool Cleaner
Pool cleaner won't work
Sounds like the filter is getting very dirty and lowering the suction needed for the cleaner to run properly. If that is the case, there are two ways to address the problem. 1. Everytime the cleaner stops, clean the filter. 2. Use a manual vac and cut the pipe that comes off the top of the pump and goes to the filter. By eliminating the filter, you should be able to clean the pool a lot faster. You'll have to empty the pump basket often.
Mar 04, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Pool cleaner Won't move
For these automatic pool cleaners, make sure that the filter bags are clean and free of obstructions. Check your impeller. Sometimes hair and other materials can get caught in the impeller and can cause the unit not to move. Finally, make sure that you are getting adequate pressure from your return lines.
Jul 30, 2009 | Smartpool Dolphin Robo - Kleen Above...
My aqua bot will not move
Check and make sure that there is no debis in the drive belts! If you are near Phoenix AZ I my be able to look at it with you. Also, the website http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Aquabot-Troubleshooting.html may be useful to look at S, Christian dansker01@msn.com
Jul 20, 2009 | Aquabot Robotic Pool Cleaner
My pump pressure is 10psi i cleaned the de filters they seem fine i have good floe out of my jets but when i hook the pool cleaner up pressure drops to almost nothing. could my impeller be the problem
The pressure you are reading is the pressure in the filter tank as water is pumped though it. When the filter is freshly charged, 9 PSI is a good pressure.
As the filter removes particles from the water the filter gets "dirty" -- it takes more pressure to push the water through it thus raising the PSI.
I think you are viewing this in reverse. Low filter pressure is "good" (as long as it stays above 8 PSI) -- as the filter cleans the water the PSI will increase -- when it gets to 15-20 PSI it needs to be back-washed and recharged.
The pressure drops when the pool cleaner is connected because pool cleaners always pull in air (in varying amounts) because of all the hose connections. This causes your filter/tank pressure to drop.
May 25, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Aqua Vac Tiger Shark Logo
150 people viewed this question
Top Aqua Pool & Spa Experts
Ben Clacy
Ben Clacy
Level 1 Expert
ray gallant
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
