Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Intex 633 lost suction
I have an Intex 633 and it seems to have lost all suction when I turn it on. I can hear the motor running but no suction. I have tried releasing air via the air valves, and I have also checked the hoses and grate where the inlet hose attaches for blockages, but found nothing. I have had the pump for three years so I wasn't sure if the pump is just at the end of its life
Thanks!
  • Electric by George Jul 13, 2010
    have you tried to force water down the intake hose to make sure any chance of air lock is eliminated?
  • seanf12 Jul 13, 2010
    I haven't...what is the best way to do that?
    Problem Solver:
  • 13 Answers
I have seen a common problem when customers change / clean their filter is that put the DRY clean filter in the skimmer box or filter holder and sometimes it can cause an "air lock"
Just take your garden hose put in the intake outlet of your pool and turn that baby on....If you start seeing air bubbles on the discharge end of the line most likely that was your trouble.
If the problem still persist then at that time look into pump repair / replacement.
Good Luck!
Posted on Jul 13, 2010
  • Helen Marks Aug 18, 2012
    This did not work for me
I have no suction at the skimmer.
maybe your pump has lost it's prime? prime the pump with it OFF and use a garden hose connected to house supply , remove hose and turn pump ON you should see dishcharge shoot out some bubbles at first then they should dissapate in -60 seconds , if bubbles continue, you have a suction side leak in maybe a filter lid or hose connection this will make the filter loose its prime after every off cycle
Jun 17, 2013 | INTEX Sand Filter Pump
Krystal clear model 633 hums but impeller does noy spin
Starter winding or cap or switch has failed. Unplug. Look for broken/loose wires or burned components, if you can't find anything you will have to replace the motor. If that is not possible, replace the entire unit.
Sep 20, 2012 | Intex 2500 GPH Filter Pump Krystal Clear...
Pool pump intex 51 pumps water but return flow is low
if you cartridge is completly clean then start by disconecting the out tube that goes to the pump housing
sometimes debris gets caught there entering your pump.
a little hair causes other things to back up
once you are satisfird that those 2 things are ready then close it all up and open the bleeder cap on top of the cartridge holder
Now let water in from the suction side
when water starts coming out of the bleeder cap then open the return side
Now turn on the puimp
let it run for 20 seconds and then close your bleeder
Should be working fine after that.
dont forget to leave the bleeder cap alone on the bottom of the canister unless you are draining the water from the canister to clean it. As soon as you are done close it back up
Jul 15, 2009 | Intex Plunger Valve & Straniner Basket set...
There seems to be no water preassure comming out of my krystal clear deluxe salt water system, model# 8111. What could be wrong? I have lost my manual and the system is indicating code 90.
sounds like air lock
disconnect skimmer ( if you use one) from inside of pool
make sure the tube going from pool to pump has no debris at the motor housing
hair can build up there then trap other debris
no open you bleeder caps till water runs freely
once water is coming out and you do not hear air turn on the pump
let run for a minute then close the caps
Jul 13, 2009 | Intex Automatic Salt Water System for ...
It has stopped cycling water it seems to have no suction
open your air release valves
If this does not work re prime the system
Jul 11, 2009 | Intex Krystal Clear 633 2500Gph
Intex filter model 633 with no instruction manual on how to set i
You can go to the website for Intex products and once you get to product section you can find and download a pdf manual
Jun 14, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
1,476 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
