Question about Crown CE2000 Amplifier
Turns off after a few minutes
Fan doesnt turn on put in a new and still doesnt work
  • 17,130 Answers
The fan works only when the temperature goes up beyond a limit.the circuit gets triggered only after this point. check the voltage to this drive circuit and the trigger. heat the thermister and see if the fan works. if the heat is not heating up do not worry about this issue at all, normally this happens only when it drives up so much. Hope this helps? good day
Posted on Jul 14, 2010
New World G90m grill turns off - overheating?
Its a good chance its the thermal control board to the fan (PCB),if faulty it doesnt allow fan to reach correct speed thus overheating.
Hope this helps
Feb 05, 2012 | New World G90m Gas Double Oven
Bmw x5 2001 the car doesnt pick up speed when put in gear and doesnt always go into gear there is a delay when put reverse I follow manual intructions turn off the engine and wait a few minutes then...
Read the trouble codes for your automatic transmission using a scan tool. I like the wireless ELM327 OBD2 adapter and OBD Fusion app.
The trouble codes will tell you why the transmissiion is putting the car in limp mode.
Dec 22, 2017 | BMW X5 Series Cars & Trucks
Have a p50h401. In last week a few times, power
yes you have some few fan in the if they doesnt work it will hover heat thats could from the fan power voltage from the prower supply or the fan it self
you can try an external fan and blow the air on
the back panel in the aeration notch if it stand
thats your problem the circuit came over heat
hope that will help
regards Alan
Jun 07, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Timer on dryer does not shut off
does the timer turn and keep turning? does it stay put? heat? try using a fluf/no heat cycle for a few minutes to see if it will turn off on its own. if it doesnt turn off then you need a new timer
Mar 21, 2010 | KitchenAid Dryers
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
Turns on and works great...after about 10 minutes it doesnt work.
it is probably because your xbox is over heatng and you have a bad or loose wire in your xbox, try to put a fan facing the back of it before u turn it on
Jun 04, 2009 | Microsoft Xbox 360 Console
My emachine shuts itself off, fan working ok, help help
Hi there. When you turn on your system, enter the BIOS setup screen. Depending on your BIOS, you may have a section that tells you the PC Health Status. If you do, you can check what temp your processor is, and it may even let you adjust the warning temp, (it may be set too low). Some BIOS's will shut down a machine automatically if this temp is reached, to save the integrity of the system.
Yes, you may have a faulty power supply. Try testing it with another and see if the same thing happens. Also, make sure that your power supply is connected to your motherboard properly. Easiest way is to just disconnect it from the motherboard, check for any bent/broken pins, then just click it firmly back into place.
If you need me to clarify anything, just post a comment.
Tim
Apr 20, 2009 | Computers & Internet
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Display problem
yes big time need cpu fan to work and new greese big time turn it on hi on bios if u can also buy acooling pad on ebay labtop cooler pad keep it cool these so hot killed power chips in it now bad mobo least get that cooler on ebay ok
Jan 19, 2008 | Computers & Internet
Crown CE2000 Amplifier Logo
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
