Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
The string on my duel fed grasshog is wrapped hopelessly underneath the spinner. How do I get the thing apart?
  • 1,498 Answers
Hi There,
Hey, it happens. But line is cheap compared to the time it may take to dismantle and then reassemble the unit. Especially if you're at a clients.
I use wire cutters and needle nose pliers to clear that birds nest quickly.
If the unit has a habit of tangling, just use less line when loading.
Call this an alternative solution.
Best regards,
Mike
Posted on Jul 13, 2010
How do you rewind the string on the black and deckder grasshog
It's annoying I know, but there should be a little notch in the spool, wind the string evenly round one groove. notch it, then do the same on the other groove but in the opposite direction. Hope this helps.
Jun 28, 2015 | Black and Decker USA BLACK&DECKER GH710...
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
Hi I have an ECHO SRM 225 trimmer. I received no manual when I bought it. I do not know how to spool a new string
Usually string trimmers come with line already in it. If there is no line in it take the head apart. how you do this is as you push down on the bump as you hold the bottom part of head and twist the head should come apart..to sting the trimmer some are different some you have to cut the string and wrap two strings two different ways some you use one long piece and you wrap it.... you will noticed on the head there will be little indicators that tell you which way to wrap the string.. if you have any questions please let me know..
Jul 16, 2011 | Garden
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
My grasshog will not advance the string and it appears that the center post that the string head fits into has worn out but I cannot imagine why. can you replace that part?
Take your string trimmer reel and throw it in the garbage. Go get a gater head and put it on, it will be the best thing you ever did.
Mar 30, 2010 | Black & Decker 14" Grass Hog Xp...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
String is wrapped around area under spool housing
Do not get spool housing off even you got problem such as wrapped string, please go to service center for help.
Sep 07, 2008 | Black & Decker String Trimmer Cordless 12"...
Black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Jun 13, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
507 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
