Question about Northwestern Bell (36582-M2) Cordless Phone
No Dial tone/ wont connect
Phone says Connecting and then Not Available. Not even a dial tone. I used the phone for a full day and it worked fine. But the next day this happens. This is a bell phone and the model # is 36587M
eagle338
  • 4889 Answers
SOURCE: phone has not dial tone or buttons have no function
This is not a problem..You will need keep your phone plugged into the power jack and the powe switch must be on.Then connect the phone line..thats all the phone will register itself and start working..
Posted on Oct 19, 2007
  • 38 Answers
SOURCE: my phone keeps saying, connecting, connecting, connecting, but no dial tone comes up, and says unavailable, what is the problem
Do you actually have a 2nd line number wired at the jack you are connecting the phone to.Try phone 2 to prove this. If these requirements are met, make sure you have 4 conductor cord and it's plugged into the proper jack in the back of the phone that doesn't work.. Thank you. Jerry
Posted on Feb 17, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Posted on Feb 18, 2008
  • 14 Answers
SOURCE: Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Posted on Apr 01, 2008
SOURCE: Dial Tone but won't call out.
Hi, I've just had this problem today and i resolved it. Does your phone have abit of noise in the background? Replace the master socket(main telephone socket) and it should be fine
Posted on Sep 08, 2008
How do I get a dial tone?
Is the base station plugged into the phone jack on the wall?
May 17, 2014 | Swissvoice Epure Full Eco Cordless...
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
Everything is working fine on my lexmark all-in-one except for the fax. It is dialing the number and says that it is connecting but will not connect. Have cut it off for a period of time then cut it back...
It could be the fax line in the wall. Try to insert a telephone straight to the wall and listen for a dial tone. If you hear no dial tone, please contact your phone company and have them check the line. If you hear a dial tone, re-plug the printer into the wall using a different known working telephone cable. Try to fax again.
Aug 26, 2011 | Lexmark X4250 All-In-One InkJet Printer
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Cannot connect to isp using modem (dialup) get error code 680. using vista home premium.
error code 680 means there is no dial tone.
manually attach a phone to the phone jack you are connecting to and check if there is a dial tone. if there is no dial tone on that jack try a diff phone jack. if still fails call your telco.
if there is dial tone to other jacks it means the previous jack is faulty or damage.
Oct 17, 2009 | Computers & Internet
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
Northwestern Bell (36582-M2) Cordless Phone Logo
21 people viewed this question
Top Northwestern Bell Lands Phones Experts
Oloyede Monsuru
David Burbee
David Burbee
Are you a Northwestern Bell Lands Phone Expert? Answer questions, earn points and help others
