Question about Apple MacBook Mac Notebook
My laptop is on but my screen won't turn on
When I close the laptop the sleep indicator light comes on in on the front of the laptop to the right of the thumbscoop. It is a steady stream of light, and does not fluctuate in and out, like it normally does. When I opened the laptop initially i heard the noise it makes every time it wakes up, but still the screen didn't turn on. Now when I open and close it, it doesn't make any noise. I've tried pressing the power button, the battery is not dead, and I don't know what else to do.
  • Apple Master
  • 739 Answers
Try holding the power button down for about 10 seconds (count them).
What happens next?
Posted on Jul 13, 2010
My screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 20, 2013 | HP Compaq Presario CQ50-210US Notebook
Screen wont come on, on my Toshiba laptop computer
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps.
Jan 15, 2013 | Toshiba Computers & Internet
I can't get my laptop screen to come on
Jan 14, 2013 | Samsung Np300v5ai 15.6" Notebook - Intel...
My HP Pavilion dv3 won't wake up.
The HP DV series or laptop are known to suffer from GPU faults and issues. The syptoms you describe indicate such a fault. To help isolate the fault you will need to try plugging the laptop into an external screen when it is powered off, Power the laptop up and if the GPU is healthy it should display fine on the external screen leaving us free to look at other issues. If it does not it likely your GPU is at fault. If this is the case you would either need to undertake re-ball/reflow repair on the GPU, which is best done by you local repair shop unless you have the tools/skills to perform such tasks. Alternatively replacing the mainboard in the laptop could be an option.
Let me know if you try an external monitor. If it does display I will try to guide you through testing for other faults and issues.
Jan 08, 2013 | HP Pavilion dv3z Entertainment Notebook
HP Pavillion screen goes black when inactive for short time. Even when I fixed all of the power settings to never shut off or go into sleep mode. If I don't use it for 30 seconds then the screen...
Dec 08, 2012 | Computers & Internet
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Sleep mode won't wake up
dont let computer go to sleep mode, just turn of screen, run disk cleaner
Apr 23, 2012 | Acer Computers & Internet
Laptop Fan and Power Indicator won't turn off.
Are you sure you are turning it off completely. Sounds like you have it sleeping or hibernating. Press and hold the power button for 15 seconds or so, it should power off completely.
Mar 29, 2012 | Computers & Internet
Gateway laptop
you and your computer need to tite lohdra ok
i thanig your problem sovel
May 05, 2008 | Computers & Internet
Apple MacBook Mac Notebook Logo
113 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
