Question about Northwestern Bell (36582-M2) Cordless Phone
No Dial tone/ wont connect
My sister bought me this phone from Alabama. The first day it worked fine. I had a little struggle with programming my personal numbers but with a little persistence it paid off. Any how, when ever I pick up the phone and press the talk button to get a dial tone, it reads "connecting".........., then "not available". There is never a dial tone present. Please help. My phone is a "Bell Phone" by Northwestern Bell Phones, and the model number is 36587M. (FCC ID: PEG36587) Oh, and I waited and charged the battery a full 24 Hrs before I began using the phone. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
3 Suggested Answers
  • 95 Answers
SOURCE: bell Phones by Northwestern Bell Phone 20200 memory function
Here is a link to the manual with the instructions in PDF format. You can wither download and print it or just follow the instructions. Glad to help!
http://www.smarthome.com/manuals/5172_Man_English.pdf
Posted on Mar 28, 2009
jesselohse
  • 128 Answers
SOURCE: How do I get a user guide for northwestern bell cordless phone mo
You will be able to download most current models at this site
· For a Hard Copy, please send $3 dollars along with the model number to:
· VTC SERVICE & MANUFACTURING, INC
· 16988 GALE AVENUE
· CITY OF INDUSTRY, CA 91745
Good Luck,
Jesse
Posted on Jan 06, 2010
One of my phones stopped ringing on my nec dtu 16d phone
Ringing is assigned in system programming, very little chance it was changed by mistake. If Do-Not-Disturb was turned on, that could make a phone stop ringing. If it's just one line on a phone, maybe the system got put in night mode by mistake and night programming isn't identical to day ring. If you have direct access to the phone line check it for dial tone. Often virtual lines are used and you can't check for direct dial tone. On very rare occasion the ringer stops working, which can't be fixed.
Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
HP Officejet 6500 no longer hears the dialtone. The line works fine with a regular phone, but not the printer. Up until a couple of days ago, it worked fine. The printer says the line is in use (wh
Usually on hook telephone line voltage around 40V DC +/- depends on exchange, voltage will drops below 12VDC if its half hook..You will get engage tone/usage tone if voltage drops less than 12V, in this condition you wont get any incoming calls.
You need to open the printer formatter to locate the modem where telephone line inserted..
Let understand why this malfunction happens..
The ring voltage between the line is +120V AC, but it should not exceed more than 200V.. To protect the circuit, line will guarded by component called "VARISTOR". The Varistor will burns if voltage reaches specified or more voltage across it.. Once varistor burns U will get engage tone always... Basic multimeter is enough to check the varistor, put multimeter in diode mode, test both ends of varistor, it should not show zero value or beeping. Some times it may burn, blast or bulge. Remove the faulty component from the circuit with the help of soldering iron, connect the line & verify, if line is good replace with same rating of component.. Chk for the ring & dial tone...
Req tools: Multimeeter, soldering iron, little paste & Led, screw driver set for opening the printer..
Depends on design varistor may fix accordingly which we need to find out the location.. But its always fixed between line in path. pl see the attached sample diagram.
if you are non technical pl don,t try it...Best of luck.. 6f4a7950-5cc9-42c6-bb47-b2ba2007add0.jpg 21aa8d50-de72-49d9-a692-6c813c2c0768.jpgEx: Varistor ac224650-2c77-4de1-934f-929cbd6f0d15.jpg Damaged/burnt varistor
Apr 01, 2014 | HP Officejet 6500A Plus Wireless...
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
I cannot get a dial tone. I press the talk button to dial out. After 3 quick short beats a message appears in the display window " can't connect ". The phone rings when in coming calls come, but...
Which make and model of phone is it?
Are you pressing the green call button beforew you try to enter the number you are calling?
You should enter the number first, then press 'green'
You wont hear a dial-tone like a landline phone
Feb 23, 2011 | Cell Phones
MY LEXMARK X125 STOPPED RECIEVING AND SENDING FAXES. IT HAS ITS OWN LINE NOT CONNECTED TO COMPUTER. ALSO MY SPEAKER DIAL TONE IS NOT WORKING. WHEN CHECKING MY DRPD WONT SET UP EITHER. THIS JUST HAPPENED 2...
Hello. If everything else is working, printing and copying, unplug the printer from the power source. Check the telephone line from your phone company by unplugging the fax machine from the wall jack where it is connected to. Plug a telephone device straight to that wall jack and check for a dial tone. If there's no dial tone, contact your phone company. If there is, plug the fax machine back to that wall jack. You can also try replacing the telephone cable with a another known working cable. Plug the printer back to the power source. Check again. Hope this helps.
Mar 23, 2010 | Lexmark X125 All-In-One InkJet Printer
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
Northwestern Bell (36582-M2) Cordless Phone Logo
54 people viewed this question
Top Northwestern Bell Lands Phones Experts
Oloyede Monsuru
David Burbee
David Burbee
Bruce Showalter
Are you a Northwestern Bell Lands Phone Expert? Answer questions, earn points and help others
