Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
I have a desktop PC, Gateway 5472. I am running Windows Vista, and a variety of productivity suites. It has a 500 GB hard drive, and 4 MB of RAM. My computer has an unusual problem...one which has perplexed me beyond description. 1) The computer shuts off in the middle of using it, without warning, without any kind of Windows messages, just shuts down. When I try to restart it, it boots for maybe 10 seconds, and then shuts off again. If I wait for an hour or so, it will reboot, but I have to run ''Launch Windows Repair'', at which point it goes through a repairing process, and eventually reboots. 2) Immediately prior to shutting down, the power supply fan is roaring like a 747, and the computer is very noisy! HELP!
  • 428 Answers
Hi, Well looks to me a problem with either your Fan (or cooling system) or RAM (memory). If your machine shuts down itself (without restarting) most probably the Processor cooling procedure has failed. Without a warning the System will shut down immediately to avoid any damage to the Processor.
  • Have you experienced a 100% CPU usage? You can check it using your Task Manager.
  • Have you checked your System Temperature? If your System has a built-in Temperature monitor use it. Or you can check it using the BIOS. It has a location which displays System Parameters. Monitor the temperature. That has to be the problem.
  • Check your fan. If it has been damaged it will not be able to function as expected.
  • Make sure your power supply is able to provide enough power to the CPU Fan and other devices.
  • Make sure you fan has no loose connections.
  • Make sure that its clean.
  • If you have problems visible with your fan, please replace it.
  • Make sure that your Processor has no loose connections. Its must be installed to the slot or socket properly. The heat sink must be installed properly.
  • Make sure your power supply has no internal leakage or extensive heat.
  • If your machine Restarts without shutting down:
  • Most probably an Issue with your RAM or Hard Disk (or an Operating System Problem has been detected).
  • If it launches Windows Repair Process it might be a problem with one of these devices and / or the OS as well rather than CPU.
  • You can use the Event Viewer to check for System Related errors. What you have to do is type Run in the search box in the Start Menu, hit enter then.
  • In the Run box, Eventvwr.msc and hit enter.
  • Go to System category and check for Errors. (Red X mark represents errors).
  • Read the description and try to check whether an error is logged. If so please post it here for further assistance.
  • You may need some hardware knowledge to perform these tasks (except the Event Viewer and BIOS check). If you do not have any experience please take the machine to a tech.
Feel free to contact again. Comment here.
Please be kind enough to rate the answer as well!
Thanks for using Fixya! Have a good day!
Posted on Jul 13, 2010
  • Tharinda
    Tharinda Jul 13, 2010
    Forgot to mention one more thing. Make sure that your system is free of Viruses and Spyware
Tip
30 gb in mb ram
what is 30 gb hard drive in mb ram?
on May 10, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
Need specs
Systemax Ascent KMA3500 Desktop
Processor :AMD Athlon 64 X2 2.3 GHz
Installed Memory :2 GB (DDR2 SDRAM)
Operating System :Microsoft Windows Vista Business
Video Output Interface :PCI Express
RAM :2 GB
Max Supported RAM :4 GB
Installed Video Memory :128 MB
Supported RAM Speeds :800 Mhz
Hard Drive :160 GB
Hard Drive Interface Serial ATA II
CD / DVD :CD-RW/DVD-ROM (Combo)
Graphic Processor NVIDIA GeForce 6100
Integrated Audio Realtek ALC833
Networking
Networking Type Integrated 10/100 Network Card
Dec 18, 2009 | Systemax Ascent PC Desktop
What mb to update from kk266plus for modern pc
you can buy DG31PR,GL / DG45PR these series mother board but you have to change your processor too with core2 duo 2ghz series, if you want to upgrade the RAM to 4GB means this is the only way have to change the following specifications (DG31 or DG 41 series board, core2duo procc,SATA seagate hard disk 500GB, 4GB RAM) this is the complete solution .
Oct 20, 2009 | Gateway 560GE Intel Pentium 4 630 3GHz(HT)...
Sims 3
These are the system requirements for Sims 3 PC version>>>>>>>
Windows XP
  • Windows XP (Service Pack 2)
  • 2.0 GHz P4 processor or equivalent
  • 1 GB RAM
  • At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
  • 128 MB video card with support for Pixel Shader 2.0
Windows Vista
  • Windows Vista (Service Pack 1)
  • 2.4 GHz P4 processor or equivalent
  • 1.5 GB RAM
For computers using built-in graphics chipsets, the game requires at least
  • Intel Integrated Chipset, GMA X3000 or above
  • 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
  • 0.5 GB additional RAM
You can download a demo version from EA Games here before you buy it >>>>>>>>
http://eastore.ea.com/store/eaemea/en_GB/ContentTheme/pbPage.sims3uk
Regards.
Jul 09, 2009 | Dell Computers & Internet
Vista RAM usage ?
The minimum recommended ram for Vista is 1 GB, generally accepted practical minimum is 2 GB. A 1 GB system will be kinda laggy. Maximum RAM for 32 bit Vista is 4 GB.
Vista Home Premium is roughly equivalent to Windows XP Media Center Edition (Has Media Center, cann't be put on a DOMAIN type network)
Vista Business is roughly equivalent to Windows XP Professional (Can Join a Domain, Doesn't have Media Center)
Vista Ultimate has all available freatures of Vista, you can do any windows function with Ultimate
Apr 26, 2009 | Dell Dimension 3100 PC Desktop
Bigger hard drive
I'm not sure if the motherboard supports SATA drives, so your best bet is getting any IDE (ATA) hard drive. It's up to you which kind you want. I've always been partial to Western Digital and Seagate.
If you are running Windows XP then you shouldn't have a problem with having a larger hard drive, I know Windows 2000 had some issues with them that required registery editing.
Dec 11, 2008 | Sony VAIO Digital Studio PCV-RZ22G PC...
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Nov 03, 2008 | Computers & Internet
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
103 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
