Question about LG 42LB5D 42 in. LCD Television
The picture does not want to come on when the room temp is below 68F, the sound is OK. If I turn it off and then back on once or twice it work most of the time.
  • 11,361 Answers
It sounds like you have bad DC filter caps in the power supply, when its cold the ESR (Equivalent Series Resistance) will go up if you have bad cap, goes down when it is warm up, I use hair dryer for locating bad caps, and small low watt soldering iron for heating up individual cap once the general area is located by hair dryer, this trick is 30 years old! You can see ESR goes down when heated if you have cap meter with ESR testing function.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 13, 2010
Is it normal for my furnace to have burner cycle once or twice
That sounds normal. When the bonnet reaches a preset temperature the burner turns off then when it cools down a bit the burner turns back on. Clean filters etc will help to keep the burner on longer in a cycle.
Aug 24, 2014 | Heating & Cooling
Dyson hot and cold fan only works in hot mode
Hi there, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 09, 2012 | Dyson AM04 Hot Cool Fan Heater White
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
Starting this afternoon: Thermastat was set (Manual) to turn on at 68, display window showed 63 but the furnace was not running. I manually set the turn on temp below 63, then up to 67 and the systrm...
Definitely a thermostat.It has 2 sections.One is a temperature reference section(what temp you want).The other is the temp reading section.If either one is bad,it will do just like you said.Sounds like the reference section is probably bad because it comes on for a couple minutes then shuts down.Since it was fine earlier in the day,I doubt there is anything wrong with the furnace because as you can see,it is temperature related.A furnace problem would be more of no operation at all,even if just dirty or whatever.The thermostat also would be a more common 'fail component' than the board.A suggestion also,both for a car and a house.During the summer,run the heat for 2-3 minutes,just to cycle it occasionally.In winter,run the A/C for 2-3 minutes.Do both perhaps once or twice a month.It helps keep the components,somewhat fresh I guess you would say,because cycling it occasionally helps to keep it going good.Also,if you encounter a problem,you may be able to get it fixed before you really need it.In the meantime,feel free to come on down to FL until it's fixed,we have room,lol.Although it's chilly now,the weekend will be 70's.(sorry)Good luck,Greg
Dec 08, 2010 | Coleman Heating & Cooling
What percent should it be set at. It is 68F
Hi google the make it will give you the temp setings
Jan 10, 2010 | Aprilaire 550 Humidifier
Makes a crackling sound while running
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 02, 2010 | Whirlpool 75-Pint Dehumidifier
My Soleus Dehumidifer is not dehumidifying
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Soleus CFM-40 Dehumidifier
My challenge dehumidifier runs ok but does not collect any water , whats the problem?
low outside temp means low inside humidity
Dec 20, 2009 | DeLonghi Dehumidifiers
Refridgerator and Freezer
Compressor may be warm but not running. What part is brand new? Would you like me to assist you? If yes please make sure your model number is correct. I'm waiting for your reply, Sea Breeze
Nov 19, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
LG 42LB5D 42 in. LCD Television Logo
Computer Repairing
Computer Repairing
