Question about Gilmour Garden
Not spraying evenly - Gilmour Garden
    President:
  • 1,545 Answers
Can you pull the spray head off to check for debris?...the most common problem.
Posted on Jul 13, 2010
Wont spray
I hope the engine wont spray... if it's a pressure washer thats not spraying the name of the unit would help... but does it build pressure but doesn't spray - check the wand
does it even build pressure ??? no - replace pump
Oct 18, 2013 | Kohler NET HP COURAGE XT-7 SERIES VERTICAL...
I have a pull out spray kitchen faucet and the spray faucet leaks around the pin that changes the water from a spray to stream. Can I get a replacement for the spray/stream head?
take old sprayer with you and you should be able to get one at a hardware or even at homedepot.most sprayers come apart. maybe the rubber ring is bad on inside of sprayer.
Apr 21, 2011 | Plumbing
Can I oil the shredder?
No, do not use oil...
but, you can lube it with a dry graphite spray or a silicone spray...
even a silicone waterproofing spray will work to lube it.
heatman101
Apr 06, 2011 | Royal PX1000MX Shredder
Porter cable PSH 1 - clogs even with thinned paint compressor 4 gal 5.1 scfm
strain paint befor using. run water in gun or thinner to see if it will spray it before using and mix paint to the consistancy that spray gun or paint requires for spraying ( fine strainer)
Feb 04, 2011 | Porter Cable Gravity Feed Paint Sprayer
Franke Kitchen Spray Head Part # 4089. Lever on top moves it from stream to spray While on Stream Spray is leaking.... Tried changing washers 1st...then tried new aerotors... still leaking
I have the same problem. By taking off both aerators, I can see that the rubber ring inside the spray head partially disintegrated. Little pieces of rubber even fell out. I can remove the spray head (it twists off; I used a pliers and rubber gloves) but I can't take it apart and even if I did, I don't know if I could replace the rubber ring.
Nov 18, 2010 | Franke Plumbing
My paint gun is pulsating instead of spraying evenly
It looks like you have a Devilbiss SRI.
Probaby the hole in the lid is blocked, The gun sprays, paint gets sucked out, no air can get back in through the little hole in the lid to replace so it stops spraying, pressures even up it sprays abit more, and so on.
Either that or you have a damaged fluid tip.
regards
Sep 18, 2010 | HVLP New PROFESSIONAL AUTOMOTIVE AIR...
Bad air flow. it doesnet seem to be spraying out of the fan correctly. In fact, i don't even get a noticable fan spray. it just sprays a round pattern no matter what i do.
Check none of the air holes int he cap are blocked. Also there is a small wheel adjuster on the left side of the gun, or perhaps even on the top which will adjust fan spray shape.
Of course you need about 30-40 PSI pressure at the gun end for it to spray properly, as well as a compressor with about 12-15cfm air flow rating to use a HVLP gun efficiently.
Apr 16, 2010 | Sharpe Manufacturing FX300 HVLP Spray Gun...
Wagner power painter 325 not spraying right-comes out in clumps and spatters even when trying with water
You should be able to adjust the spray pattern to clear this up. You may also give it a good cleaning with mineral spirits as well as making sure that the paint is thinned enough
Mar 12, 2010 | Wagner Power Products 0154842 Medium Spray...
Problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Nov 19, 2008 | Air Tools & Compressors
Garden Logo
269 people viewed this question
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
