Question about Jl Audio E6450 Car Audio Amplifier
Engine noise coming through one channel
I just hooked up my JL e6450 amp and as I drive and my RPM's increase there is a noise in my right rear channel that increases in volume with my engine speed. What could be wrong here?
  • 1,940 Answers
This sounds like alternator whine. Do you have the power and ground connected to your battery, or through the accessory power? Make sure the power and ground wires are sufficient size, and connected to your battery, and make sure you have the power wire fused no more than a foot or two from the battery. If it is only on the right channely, maybe this wire is getting feedback from another wire. Seperate the wires if this is the case.
Wires create magnetic fields, and if a speaker wire is next to a power wire or something, you will hear a noise, typically high pitched whining.
Posted on Jul 13, 2010
I can't find where the fuse is located at on my jl audio model e6450 so I can check and see if it's blowed are not
Amps that big are usually fused on the feed wire, under the hood of the car, near the battery.
Jan 30, 2016 | Jl Audio Car Audio & Video
Engine is stalling when turning right
H JL, As the problem is apparent only when turning right, I believe there is a problem with the idle up solenoid or the vacuum pipes connected there. The unit is situated on the steering box and increases engine RPM when the engine comes under increasing load, when demand is increased while turning. Regards John
May 01, 2013 | 1990 Nissan Pathfinder
Uncontrolled downshift of 1994 c220
no 4-3 or 3-2 downshift
uncontrolled downshifts outside range of kickdown switch
poor acceleration from stopped position
parking pawl will not engage
selector lever does not engage in r or p
engine will not start in p or n position
smoke in exhaust (fluid loss)
fluid loss between torque converter & primary pump
howling noise when changing gears (under full load)
howling noise which increases as engine rpm increases
1st gear & reverse too loud
3rd gear too loud
rattling noise at 1500 rpm in all positions except r
light grinding noise in p & n positions
rolling noises when driving in reverse
vacuum control circuit
Vacuum Control Valve (E300D & S350D)
Vacuum Amplifier (E300D & S350D)
Dec 02, 2012 | 1994 Mercedes-Benz C-Class
I want to hook up subs and a amp in a 2008 saturn vue how do i do it
If you are planning on using the factory stereo you will need a line level converter. You basically connect two of your speaker channels to the line level converter. That in turn will give you a line level out (RCA cables) That line level out can be fed to a two channel amp which would be where your subs would hook up to. If you do this however you will lose two channels of mid range and highs ( your rear speakers ). Downfall to this approach is that some line level converters are susceptible to alternator noise.
If you have an aftermarket deck this will be much more simple. You simply run your RCA outputs from your deck to your external amplifier. Aftermarket decks typically have front rear and subwoofer outputs. That means you can drive a four channel amp for your front and rear and a two channel amp for your subwoofer. This is the recommended way to go.
For hookups I just suggest buying an amp kit that is comparable in power rating to your amp. If you buy a 500watt amp make sure your wiring kit can handle at least 500 watts.
Feb 12, 2010 | Jl Audio M5122.4 Diamond Audio 12" Car...
When i turn on the key the protect light comes on and it makes a funny sound
Something is shorted most likely. Check the wiring to your speakers. Check especially for stray strands of wire where the speaker wire connects at the amp and speakers.
Nov 16, 2009 | Jl Audio E6450 Car Audio Amplifier
Wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
Jul 07, 2009 | Scosche Industries Scosche Slc4 Speaker...
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Jl audio e6450 cuts out above mid-volume
take a look at the power, ground and remote wires. the power and ground should be a minimum 6awg in wire size, and the remote wire at least 12awg. it sounds like your drawing a lot of power,so smaller wires usually mean more heat...the amp will turn off into protectedmode if it gets hot or is used for along period of time,so on any road trip make sure if isnt msothered by sleeping bags,coolers etc...just like any major electronic component, it needs room to col off.
Sep 02, 2007 | Jl Audio E6450 Car Audio Amplifier
Jl Audio E6450 Car Audio Amplifier Logo
120 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
