Question about Miele Premier-Plus Built-in Dishwasher
COST OF CONTROL BOARD MIELE DISHWASHER G841 - Miele Premier-Plus Built-in Dishwasher
  • 177 Answers
Best to call your local Miele service agent or Miele office as the price will differ depending serial number and the county you live in with the exchange rates etc
Posted on Aug 18, 2010
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
The door on my miele G481 built in dishwasher won't stay open it's really annoying that it keeps popping up when I'm trying to load.
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
May 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
The breaker keeps shutting off when I run my dishwasher. Service already changed the intake hose. Is it the motor?
rarely. next time this happens. immediatly go to the breaker box, and feel for heat on the breaker that is blown. if it is warm, your miele is okay, call an electrician.
Oct 07, 2009 | Miele 23 in. Novotronic G841 Built-In...
No start
hello i'd check to see if theres a glass fuse in side the dishwasher it will be on the power board good luck
shaun
Aug 31, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I had a similar problem with a different Miele. I found that under the door, there is a removable trim panel (may not be one on yours). Under the trim panel was an acoustically sealed metal plate held by a couple of screws. i switched off and disconnected the electrity, then removed the plate. The bottom tray was filled with a big puddle. I cleaned that up and put the machine back together and it ran fine. Accordingly, I'm getting some replacement shaft seals for the thing as it looks like its worth fixing. Good luck with yours. rupertvdP
May 31, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele Novotronic dishwasher G841
I asume U R talking about the Drain Hose?? As long as it doesn't get Kinked, I see no Problem.. I installed one yesterday the (25th) and the Drain comes out under the Dishwasher, so therefore, the Drain Hose has to be ran under the Unit.. No Problems !!! I hope this Helps U out...
Jul 19, 2008 | Miele 24 in. Novotronic G851SC Plus...
Parts
You could buy a no name door seal gasket from any dishwasher parts supplier but you will loose your warranty with Miele. And extended warranties reach up to 6 years if you bought it from a factory authorzed dealer with a factory authorized installion! Call Miele direct. Miele's number is 1-800-843-7231
If you would rather call your local Miele dealer, they'll be more than happy to do help you!
Oct 13, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele Premier-Plus Built-in Dishwasher Logo
418 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
