Question about Air Tools & Compressors
Shut off while using and won't restart, is there a reset button like on a garbage disposal ?
  • 760 Answers
Well without model number and brand, it is impossible to say, but there could be. Motors on equipment quite often are thermally protected. They could be manually reset or automatic. The manual resets are usually a red button, usually somewhere near where the wiring enters the motor. Press it HARD to reset. If that was the problem, now you must find out why it overloaded. Was the pressure set to high? Did it run very extended period of time and overheat? What is the duty cycle of the compressor you have. Did you exceed that duty cycle? Check to be sure you have power on the circuit you are operating it on.
Posted on Jul 13, 2010
Is there a reset button on badger 15ss?
Usually the reset button is located on bottom of disposal near where wire is connected..
Use your hair mirror to look at bottom of disposal.
More disposal resources for troubleshoot, maintenance, repair and installation:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
Feb 25, 2015 | In-Sink-Erator InSinkErator Badger 3/4-HP...
Reset button not working on kitchenaid garbage
Look for small pieces in the disposal... likely pits, glass, etc once these are removed press the reset. also check the breaker. Double breakers can be tripped but you can't tell to look at it. Just shut it off and turn it back on.
Aug 22, 2013 | Hardware & Accessories
Garbage disposal quit working. Just stopped
Press reset button located on bottom of unit.
Use broomstick down inside disposal to make sure cutter disc rotates freely.
Copy following link for troubleshoot and illustrations:
Gene
h
Aug 19, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
Titan garbage disposal
Push reset button located bottom of disposal? Use broom stick and rotate stuck cutter disk?
Copy following link to troubleshoot by type of problem:
Titan appears to be repackaged sinkmaster garbage disposal.
There is no service manual or installation manual on brief web search. However link above has manuals sinkmaster and other brands .
Add a comment and say what you discover
Jun 09, 2013 | Garbage Disposals
My garbage disposal won't turn on, and i've felt down there and can't feel anything blocking it...what can i do now
Check circuit breaker.
Check red reset button on side of disposal and see if it's popped out. It's under sink, next to wire connection on disposal.
See if electric switch has gone bad. Listen if disposal makes humming sound. Humming means electric power is good.
Use vacuum cleaner hose instead of hand to check for stuff inside disposal
Use wood broomstick and see if cutter disk rotates freely.
If disk is stuck, wedge broomstick against side of sink opening until disk comes free, or use allan wrench on bottom of disposal.
If electric power to unit is good, and reset will not reset or reset is not tripped out, and if cutter disk rotates freely, then disposal has gone bad.
You can continue using sink as long as there is no leak that will damage cabinet underneath.
I wrote ex disposal replacement steps from my apartment maintenance days.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 15, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I get power through the reset button. No humming, no nothing. Is it a bad motor?
If i understand correctly, you tested the wires where they connect to the garbage disposal.
Those wires connect before the garbage disposal reset button.
If the reset button is locked in, then the reset is not popped out.
If reset will not reset, then the popped-out reset will push in but not click down.
If the reset is clicked in, and you hve 120V on the line, and the garbage disposal doesn't make any noise, then the motor is bad.
There are no replacement parts for garbage disposal.
Oct 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The disposal turn on but does not crank. Do I need to somehow restart it? There is no reset button.
There will be a reset button on the bottom of the unit, they all have one, hard to locate, turn power off, push in button, should be good to go
May 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Air Tools & Compressors Logo
123 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
