Question about Maytag EPICz Electric Dryer
My maytag epic z electric dryer spins but doesn't dry the clothes
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag electric dryer model # MDE2500AYW
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance:
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
jonniewalker
  • 1031 Answers
SOURCE: My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Posted on Feb 21, 2009
SOURCE: Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Posted on Jun 23, 2009
rogrrabbit
  • 986 Answers
SOURCE: maytag dryer electric mde2400ayw doesn't seem to
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Posted on Sep 12, 2009
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag epic electric dryer takes a long time to dry clothes
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
Nov 17, 2013 | Dryers
My dryer does not shut off and doesn't get hot. It takes almost 5 hours to dry a load of clothing.
Sorry to say but it sounds like the heating element is on its way out... Happened to ours and repair was more than a new dryer so we brought a new one
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag epic z dryer won't spin
Check the thermostat of your dryer first. If this does not work out, then please visit Clothes Dryer Element.
Oct 24, 2012 | Maytag Dryers
I have a Maytag Neptune electric dryer model # MDE9700AYW and I have a fault code " FE " & the dyer doesn't dry the clothes. What is my problem
Maytag Dryer and FE code means power source "Frequency Error".
Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts
Hope this helps (remember to rate and comment this answer).
Jul 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My maytag Epic Z washer won't spin. Flashed F-01
f1 is a bad control board,you can try unplugging the dryer for like 5 minutes and then plug it back in,sometimes that will reset the board but most likely you'll have to replace the board.
Feb 12, 2018 | Maytag EPICz 6.7 Cu. Ft. King-Size...
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Dryer is not functioning (It doesn´t get clothes dry)
Usually the ignightor goes out in them. If you have a meter or way of measuring it, you can take off the front panel and it'll be on your bottom left side. You can disconnect it and you should see a short. here is a link to look at and it might help in the dissasembly prosess. By the way, when you 1st turn it on, you should hear a click within seconds down my that also. If it clicks it's very much so the ignightor. Pretty easy and cheap to do. Good luck
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=MDG7400AWQ&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY
Mar 14, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag EPICz Electric Dryer Logo
139 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
