Question about Quantaray 135-400mm f/4.5-5.6 for Nikon AF
Lens shoots while aiming downwards, no while level or upwards
Hi.
I just bought a used Quanteray 135mm - 400mm lens from Craigslist.
When I tried to shoot with it with my Canon 20D, it only works when the camera and lens are pointed in a downwards direction. When the camera is held level or when it is aimed in an upwards direction I receive an Error99 message.
I have 6 other lenses that I use with the same body and do not receive this error.
What would you reccommend?
Thanks much!
~Chris
  • Quantaray Master
  • 5,412 Answers
Sounds to me as if some of the electronic connections are not completing the circuit properly - have you tried cleaning the contacts on both the camera and the lens carefully with a lint-free cloth and some IPA ?
Posted on May 22, 2017
SOURCE: Canon error codes
Canon built their new Digital cameras so that osome older non Canon lens won't work properly with them. I have a Quantary 70 - 300 f/4 - 5.6 that I used on my Rebel film camera, I bought the Canon 350D and ... You guessed right I got the same error code as you did. I palyed around with it untill I figured ou the problem - You must shoot with the apature open all the way. Move the knob to AV and open the apature as wide as you can - You'll notice you can now take pictures. The lens is somewhat crippled now (only wide apatures) but at least you now have control and understanding of the error code. Hope you find this usefull. J.
Posted on Aug 26, 2007
SOURCE: I get an error 99 message (turn power switch to off then on again or re-install battery)
I posted a problem, and have found a partial solution, at least if you get the error while shooting. After cycling power to clear the error, try lowering your ISO setting - it may need to be lowered a bunch, so keep trying. Mine cleared up when I went from ISO-800 to ISO-200. My testing is limited, so this may be only a partial fix.
Speculation (based on working with electronic sensor arrays): I believe the camera is indeed trying to protect the sensor. ISO basically sets the sensitivity of the sensor to light. The camera probably calculates the expected sensor signal before each shot, regardless of mode. Sensor signal is a function of ISO (sensitivity), shutter speed (integration time), aperture, and light input. It has influence over shutter and aperture, but none over ISO. It likely gets to a point where it can't solve the equation, so shuts down and gives an error, as user-error is not the only reason it could fail to solve the equation. Going to M would likely exacerbate the problem. I hope this helps.
Posted on Sep 06, 2008
SOURCE: Quantary Tech-10 75-300mm use with Canon Rebel XTi
Contact Quantaray. they fixed it for just shipping and handling.
Posted on Oct 18, 2008
  • 67 Answers
SOURCE: Problems getting Quantaray AF 70-300mm lens to work with Canon xt
you could try cleaning the contacts on the camera and lens with an pencil eraser
Posted on Dec 16, 2008
  • 302 Answers
SOURCE: I have a Quantaray 28-200mm lens that I used on my
The short answer is no.
The Long answer is maybe. You'd have to call some stores that carry the Quantaray products. Get phone numbers for the distributor, warranty repair shops, and maybe Quantaray home offices which may be in another country. Then you can find out if they still have the mounts for those lenses in stock, can it be done, where to send it, and how much. Mind you, they may have to totally change the electronics and the motors inside the lens too.
Posted on Jan 03, 2010
I have just purchased a canon eos 600 digital camera.efs 18-135mm lens All excited.\r\nBought it home and on autofocus can't zoom the bird on the dam up very close? I can look through my point and...
Your not doing anything wrong, your Panasonic probably is using digital zoom (which is basically just cropping the picture imitating zoom). Your eyes sees similar to a 50mm lens so your 135mm lens is less then 3x zoom.
Do not be discouraged you will soon learn your cameras strengths and weakness.
Good Luck
Jun 15, 2011 | Canon EOS 60D Digital Camera with 18-200mm...
How do I adjust my Canon EF 100-400mm infinity setting on the lent. 300 to 400mm is out of focus.
I don't know your photography background and skill, so these tips may seem overly basic.
Have you tested this on a tripod? Not using a tripod can add a lot of blur, even while using the IS.
I would also try the lens at f/8 and see if you have the same focus issues. If not, it may just be related to shooting the lens wide open, where it's not the sharpest.
I hope this helps. It's just a few things to try.
Send a comment if you'd like some other possibilities.
Happy shooting with a great lens!
Mar 06, 2011 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
MY CANON EF 100-400MM USM LENS WON'T ZOOM PAST 150MM
Is the lens tension adjusting ring too tight? Try loosening it and see if you get increased travel. If so, you may need to have it checked out.
Feb 05, 2011 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
The segment just below the distance scale wobbles. This is the segment that mounts to the camera body, not the mount itself but the entire segment. When I want to use it I must hold the lens because it is...
Do you mean the tripod foot ? If so, there is a screw with which to tighten it. If it is not that, then it will need servicing or repair, which will be expensive.
Dec 18, 2017 | Sigma APO 80-400mm f/4.5-5.6 EX OS Lens
My 400mm lens is so hard to slide out when I go to zoom what do I do
turn the 'lock/friction ring' (metal band just below the black rubber focusing ring) counter clockwise whilst holding the focusing 'ring' still. The friction/lock ring is used to prevent 'lens creep' when carrying the camera with lens pointing down, or using the lens when it is pointing down. Juust turn it until it applies the level of friction you prefer for operating the lens. If you have already tried this and it won't budge it may be the bearings are shot and you will need to contact a canon service centre for repair.
Dec 03, 2010 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
I have vivatar 100-400mm lens with stripped out
Try Protech, Uckfield, East Sussex for estimate of repair cost
Mar 13, 2010 | Vivitar 100-400mm f/4.5-6.7 Series Lens
I have a code fEE. I can't shoot. What's up?
Usually means that you have a lens with the aperature in the wrong setting for use on an auto aperature camera. Look at the lens and move the aperature setting to the red marking.
Don't feel bad, this one got me for about a half a day two different times the first time I put on my new 50mm f1.8 lens. Great lens, but I'd never had an "old style" lens before.
Just for reference, if you put an old manual lens on your D80, it will show F-- in the aperature display and won't take pictures except in "M".
Sep 01, 2009 | Nikon D80 Digital Camera with 18-135mm...
Can't get F3.5 aperture on the 18-135mm kit lense on d80
You may be shooting auto and there is too much light. If you want to be sure you are shooting with 18mm @ f3.5 then shoot with aperture priority (the shutter speed will adjust automatically). Ususally at a wide focal length you would want a small aperature (smaller f-stop) so this should not really be a problem.
Feb 14, 2009 | Nikon D80 Digital Camera with 18-135mm...
Questions on disassembly for sigma 400mm apo af
Hi
Sigma will not repair this lens as the fungs may be in the lens on the barrels and if thay could clean
or replace optics the fungs may come back so thay cannot give a guarantee I know someone who
cleans lenses let me know if you want to contack him
Apr 08, 2008 | Sigma 400mm f/5.6 APO Macro for Nikon AI
Quantaray 135-400mm f/4.5-5.6 for Nikon AF Logo
Top Quantaray Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
teddyboy
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
