Question about Kenmore 75085 Air Conditioner
Plasmaire 580.73089300 buzzing loudly and not cooling
I just installed a plasmaire 580.73089300 and the unit starts to buzz intermittently (very loud). Also is not cooling nearly as well as last year! Any clues as to what this is and if it is worth fixing?
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave buzzing
It's likely a bad magnetron or maybe the high-voltage transformer. If it's within the warranty period of the magnetron (5 years or less), I would call Sears. In my professional opinion, no one should work on a microwave unless they are fully informed and aware of the deadly hazards and necessary precautions. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Mar 23, 2007
classaxe
  • 3 Answers
SOURCE: loud buzzing noise during operation
Same thing happened to me today with our Kenmore 66515862990.
Probably there's something stuck in the drainage pump - in our case a tiny plastic domino was causing a heck of a racket.
On our model we needed a star type driver and a nutspinner driver to dismantle the unit, and a wetvac was essential to get out the water and offending blocking item(s). There's an exploded view of the water pump at searspartsdirect.com - see here - they have otrher diagrams. I had to dismantle down to part 25 in the diagram to get at the offending article. There are two white plastic balls i the assembly - these are NOT junk and they need to go back there when you are done. Take care not to damage the part number 40 or you'll get a leak when you are done. Hope this works for you!
Blessings,
Martin Francis
Posted on Dec 23, 2008
  • 25 Answers
SOURCE: makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Posted on Jan 14, 2009
  • 42 Answers
SOURCE: makes a loud buzzing sound when washing
This buzzing sound can be from a couple things. A lose a lose kick/access panel when the motor and pump is in operation can cause a slight vibrating noise. Try tightening securing the dishwasher and kick/access panel.
Second, (most likely) their can be an obstruction or debris in the water pump. You may see a plastic grid (4" x 6"; filter like) in the right rear of your dishwasher; Try removing the grid (1 or 2 screws 1/4"/cross tip), then use a dry-vac to remove any debris. *
Safety: As a beginning, please remember to perform the repairs with the power-off and ensure you have water in the dishwasher before restarting the water pump cycle (the water-pump can become damaged while dry-spinning and water enters the pump suddenly)
Posted on Jan 26, 2009
  • 659 Answers
SOURCE: loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Posted on Apr 10, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
How to change the refrigerant on my Kenmore plasmaire.
This a job for the experts as the correct amount and type of refrigerant gas is required. IN all honesty if the machine is working and cooling/freezing as required then don't fix it . IF not then there may be a sealed unit / compressor problem or a thermostat problem. Machines that are working properly will work for many, many years without a change of gas unless they develop a leak from a sharp object during the defrosting process.
Jul 06, 2014 | Refrigerators
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
(Tilted) Plasmaire spits water into room....
What your problem is is that water coming back into your face is condesation. Appearently there is a clog preventing your condensation water from draining out the back side of the a/c You can remove the a/c from it's sleeve, take it outside and with a pump sprayer (Type used for spraying insecticide) filled with water spray around the base of the a/c where the condensor coil sits (you should see a small drain channel in this area) If this drain channel is clogged water will back up and the squirrel cage will pick it up throwing it out into the house.. Good Luck on your repairs
Dave
Sep 03, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Sears Plasmaire spits water into room
It's probably just holding water somewhere and getting thrown out. I've seen people drill holes on the bottoms to drain water quicker.
Sep 03, 2009 | Kenmore 75085 Air Conditioner
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Aug 19, 2009 | Refrigerators
Loud buzzing after heating up
the buzzing is normal.  there is an element inside the quartz tube much like a filament in a light bulb.  as this heats up it starts to move.  where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
Oct 13, 2007 | Marvin Quartz Radiant Heater
Kenmore 75085 Air Conditioner Logo
100 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
