Question about Video Game Consoles & Games
Hard drives keeps on running at idle
My hdd seems keep on running even my pc is at idle. I have win xp pro sp3 with 1 gig of ram. had check running application by "ctrl-alt-del" but nothing is listed running.
  • 30 Answers
That is because the computer is constantly maintaining a check between your HDD and the Motherboard in order to make your computer actually work. Unless the HDD is making ungodly clicking noise then it is functioning normally
Posted on Jul 19, 2010
Hi
Well about guaranteed your 2 gigs ram is probably DDR II ram which has maximum of four gigs with 64 bit processing and 2 with 32 bit is. So motherboard needs upgrade. 35.00 for good giabit or board with 1000 megs a sec ethernet lan. With ddrIII ram. And upgrade operating system I believe win 8 has max 16 gig ram win 7 uses 8 gis vista and longhorn 64 use 4 and xp normal edition 32 bit uses 2 max. So you about have to run win 7 or 8. Win 7 will become direct x incomparable at some point making us change to win 8. Win8 cost like 300 to 350 and tiger direct.com has good deal of the win 7 pro media center for 75 bucks. So spend 150 on good speed 8 gig ram, 125 bucks for 12 core and at 4 GHz I think. And a board for 35. Reuse all other componets. And you\'ll have a 2500 dollar computer and best on the block. TigerDirect com Electronics Tablets Phones Office Supplies Video Games
I’m happy to assist further over the phone at https://www.6ya.com/expert/christpher_f760d0f18f8eedc3
May 16, 2014 | Video Game Consoles & Games
1 GB increase
hi
not every motherboard or on board video is compatible with windows 8
what windows was it running previously
windows 8 was designed for 64 bit platforms which requires 4 gig of ram but you have to also take into account the other hardware components and there maximum configuration
i have run win 8 on 2 gig of ram but it struggles with you tube downloads
i upgraded the ram to 4 gig and run win xp win 7 and win 8.1 on the hard drive
cheers
Apr 05, 2014 | E-Machines eMachines Desktop PC
W3400 runs very slow, 64 bit, 2gig ram xp-pro
Your hard drive has the defective, there are bad sectors already in you drive, that's why it run slowly even though you formatted it.
Mar 27, 2012 | E-Machines W3400 PC Desktop
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Motherboard specification not available.
Are you uning the recovery CD or a new OS?
A new Os (XP) will allow the second drive even if the old one will not. Of course you can always add a USB hard drive and a USB PCI card to make it all work. What are you using this pc for seems a little old for todays applications. Suggestion If your going to use this that you Replace the main hard drive with a 120GB or larger, new video card at least 256MB if not 512 and at least 1 gig of memory as I believe it will only take a max of 1 gig. you cannot use vista as it requires more resources than this Pc can give to support the OS. you may want to try XP LITE as well one you get XP installed to speed it up a bit!
Joe
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
Apr 16, 2009 | HP Pavilion dv1000 Notebook
Windows XP won't boot with "CREATIVE SOLUTIONS" PC
That machine is too underpowared to run xp pro.
Windows XP Media Center Edition
1.6 GHz CPU, 256MB Ram, and DirectX 9 hardware-accelerated GPU
you may get it to run but it is going to be dead slow. you will be waiting forever to load any apps with a processor under a gig, and less than 512 mhz of memory, it may work for emulation, but that's even questionable. I don't want to aggrvate you but that config is a decade old. Vista for instance needs at least 2 gigs of ram and a dualcore to run right. sorry bud, if you are dead set on it, the only thing you coula do is juice up the memory, to whatever the board is rated to take, or I would run windows 98, peace
Feb 03, 2009 | Dell XPS™ 600 PC Desktop
160 gig sata hard drive that keeps on failing
hello what brand is ur hard drive. western digital has software that can scan ur hard drive for possible hard ware errors, as does seagate. in addition ur motherboard may have a test that may help (smart something not sure but good luck)
Jan 24, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
Video Game Consoles & Games Logo
111 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
MegaByteMe
MegaByteMe
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
