Question about Dishwashers
My dishwasher makes a banging noise whenever the water supply shuts off & it drains. It has been doing this for a long time. I finally bought a hammer arrester & soldered it on the line after the tee for tap & dishwasher & it sits about 1 foot up.this did not solve the problem. It still bangs loudly & I'm worried about damaging my pipes since they are old copper pipes. can you give me some advise it is a ge Potscrubber mod. #SSD539PS1181 Dave
  • 35 Answers
SOURCE: GE fridge and dishwasher
For GE Model# GSS25SGRESS
replace the evap fan motor in the freezer..or have it checked
PART# WR60X10185 W/O THERMISTOR
PART# WR60X10074 WITH THERMISTOR
Posted on Mar 02, 2008
Master_Tech
  • 770 Answers
SOURCE: LG 3 in 1 Dishwasher model LD2131SH
E1=Water inlet Error
Not reached to the normal
water level in spite
of 10 min. water supply
Causes:
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker.
Posted on Aug 20, 2008
  • 449 Answers
SOURCE: Loud noises, bangs and sounds like water falling
if it’s a banging sound--- I know one of the noises the system 2000 will make is a bang or rattle at the end of the run cycle, which we call "shudder stop". If this is your noise then I have to give you some bad news here. Sorry....... The only way of repairing this is by having your compressor replaced as it has to do with an internal problem in the compressor itself. There may be a silver lining, though, if you are the original purchaser and you have the receipt. Some of these systems came with a 10 year warranty on the compressor, so you might want to check this out.good luck
Posted on Dec 19, 2008
onthejob5130
  • 640 Answers
SOURCE: Water supply line vibrates making very loud noise.
these vibration in water pipes or cooper lines come from air in thewater supply system..dont take your appliances apart...
Posted on Dec 26, 2008
skrbin
  • 121 Answers
SOURCE: indesit wil 113 washing machine
try to put more clothes but not to much it wont banging.
must change door lock switch.
Posted on Feb 17, 2009
Ignis dishwasher not working. When switched on a loud banging noise but there's no water?!
you need to take the drain pump off and clear whatever is in there. Pull the dishwasher out, remove the bottom cover or gain access to drain pump. Thats what it sounds like
Feb 14, 2013 | Dishwashers
After completing the wash & rinse cycle the dishwasher won't drain
In my experience, in this case it is likely that your dishwasher is not draining at any time throughout the wash or rinse cycles. The overflow float is preventing your machine from overflowing.
Here are a few things to check:
  1. If this is a new install, or the disposal has just been replaced, make sure the plug in the disposal has been removed. The nipple where the drain line from your dishwasher attaches has a plug on the inner wall of the grind chamber from the factory.
  2. Listen to the sound of the drain motor by starting a cycle and then canceling after a few seconds. Make sure the drain pump is actually running and not just making a loud humming noise as if it is seized, or something is binding it.
  3. Finally, check your drain line from your dishwasher to your disposal (most common drain connection), or where ever your drain line connects. Slight kinks and sharp bends have a tendancy to collect debris and create a plug-up. If this is the case, simply take the drain line loose from the drain pump and from the disposal and take it an outside water faucet. Place the disposal end against the faucet and slowly turn on the water. It will usually blow the plug right out.
Apr 16, 2011 | Dishwashers
WATER REMAINS IN WASHER AFTER CLEANING CYCLE
Possible that the drain is blocked/choked or the drain pump/valve is faulty. You must remove the drain valve/pump and make a good cleaning of the unit . check on the outside with the voltage sepcified to confirm.
Finally make sure that the program controller unit supplies voltage to the unit till the water drains off. if not the time and the drain flow can be low. Keep the washer tilted to the drain flow.
Feb 14, 2011 | Electrolux 23 in. ESL624 Built-in...
A loud noise from the pipe that connects the dishwasher under the sink. Would that be a problem with the machine??
When the solenoid turn on to let water into the dishwasher and when it turns back off it can cause the pipe to jump. I will assume that it is banging into something. If so over time it could create a hole in the pipe or tube. I'd try and figure out what it is hitting and move one or the other things.
Sep 20, 2010 | Whirlpool Dishwashers
Water will not drain out
Check the drain filter located at the bottom of the wash tub. Clean if clogged. The pump noise could be due to non availability of the washed water continuously due to clog.
Clean the drain filter. Check the final drain output after the pump(hose) for free flow if you have connected it to a drain system.
Aug 03, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher is not draining and is flooding out the side
It sounds like the float valve is clogged and or you have a timer problem (which is way down on the list of probabilities...very rare...last thing to happen generally ...but not impossible.)....on the floor of the DW is a round Mushroom looking float valve that rises with the water and shuts the water off at a specific time...usually when full....it often gets gunk in it...(soap...debris...etc) and it sticks in the down...too much water...or in the up...no water....position...take it off...just lift up...and listen for a clicking noise...check to see if it is clean...if not clean it and replace it...push it up and down listening for the clicking noise...if you don't hear one...then it may not be making contact with the contactor...check to see that it does...and it it is and no contact noise with movement replace the contact.
Also some DW's have a sump (drain ) area where water collects to drain...sometimes debris collects in this area....and inhibits drainage...check to see that no debris (careful could be broken glass) is inhibiting drainage.
Hope this helps....and good luck...let me know if it does not... thanks for rating my effort...The Fang.
May 19, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Causes:
(below 10 psi)
Inlet Valve is OK?
by impure water.
Solutions:
device.
by the Test Mode.
Aug 14, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
103 people viewed this question
Top Dishwashers Experts
