Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
Need to fix the printer fax - Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
    Brigadier General:
  • 3,917 Answers
Hi
Please download the user guide for your product, since you have not stated any specific query….
http://www.retrevo.com/support/Brother-MFC-3360C-Multifunction-Printers-manual/id/1071ag219/t/2/
Also check this useful link from brother solution center…
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc3360c_all.html?reg=us&c=us&lang=en&prod=mfc3360c_all
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 13, 2010
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I have an 6500 fax scan printer and it keep saying that the fax send report is set to off and no one changed it - HELP how do I fix it?
Press the SETUP/MENU button on ur printer's front panel
got to fax menu
Under that you will find an option which says Fax Delivery report .. it must be OFF all you need to do is turn it ON
Jan 05, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Recieve the fax and print the pages well. But, when I send the fax to other fax it prints two black lines on the right side.
The problem should be from the printer fuser assembly, the other party will need to replace there fuser assembly on there printer, once that is done, the problem should be fix.
Take care.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
Hello my fax machine keeps giving me error codes how do I fix this, I need my fax machine. thank you
Hit the setup button, select fax setup or setup fax, and make sure the option to "Junk" fax blocker is off. The default when you setup the machine itself is on yes. This helped me with my "error 410" message I received when printing fax log.
Mar 15, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Error 322 - see printer message
The fixing assembly (The hot rollers) of the printer is faulty. This need to be replaced by a service technician.
Faxes are received in memory because they cannot be printed.
Nov 11, 2009 | Canon FAX-L350 Plain Paper Laser
Will not fax out, or receive faxes
Check the FAX cable and make sure it is a FAX cable. There should be only 2 gold
contacts when you look at the cable jack. Phones use a 4 contact cable.
May 27, 2009 | HP Printer/Scanner/Copier 2210 Ink-jet...
Setting Kyocera KM-2025 Fax
the issue needs to be resolved on the other end..It's not an issue with your machine...They need to do 1 of 3 things...either setup distinctive ring with their phone company...or purchase a fax line.. or get something called "the stick"
Apr 01, 2009 | Kyocera Mita KM-2050 Printer
Outward faxes
can you receive fax?
if you can, then the line is fine. you need to configure the printer to fax following the users manual.
Mar 24, 2009 | HP Officejet 5610 All-In-One InkJet...
My fax keeps saying no anwser how do i fix this i need HELP!!
call the number you are faxing from a regular phone. If you get fax tones you need to check you fax line. Plug a non-digital phone into the fax line and place a call. Try that and let me know the results
Dec 13, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
