Question about Kitchen Ranges
When i try to turn on the oven it stays on for a few minutes then goes beep and the clock lights start flashing and the oven turns off
    Genius:
  • 1,073 Answers
Check the oven sensor wiring from the sensor back to the control board for broken wiring
if the wiring is ok then ohm the sensor with an ohm meter
if it shows no resistance replace the sensor
if it shows resistance replace the control
i would suspect the sensor
Posted on Apr 20, 2008
We cannot turn the oven on! No instruction manual. The 'A' is flashing on the 'clock'/timer - what does this mean?
This means it is in auto mode. It must be in manual mode for the oven to work. Turn the oven to ON. Some clocks have 2 or 3 buttons. Press the buttons at the same time/try all different combinations. This might take a few minutes, be patient. When the oven indicator lights the clock is in manual mode.
Apr 01, 2011 | Ovens
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 | Ovens
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Nov 04, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Set, Start and Time Beeps
im going to contack a friend of mine at ge technical about issues on this oven after holidays check back
Dec 31, 2006 | GE JKP15 Electric Single Oven
Kitchen Ranges Logo
115 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
