Question about GE Refrigerators
Frige/freezer side by side water leaking at bottom freezer door.
Frige/freezer side by side general electric.Have noticed that freezer side is leaking water at bottom of door frame? Ice cream in freezer is also melted, could the thermostate be the problem?
    Genius:
  • 1,075 Answers
Your freezer is in defrost for sone reason,how old is it/has it being giving trouble latly.replace or call an engineer,it might be cheaper to replace.adrian,,,,
Posted on Jul 13, 2010
FRS26KF6EMB
The water valve sounds like it may be leaking and the drain hole is plugged if this is a side by side the drain is in the very bottom back. sounds like it is actually a two problem situation you have. watervalve bottom back outside frige and drain in the back bottom of freezer.
Sep 23, 2012 | Frigidaire PLHS267ZA Side by Side...
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Mar 19, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water slow ice not thick
if you have a side by side frige thin wen you open the door on your frige side thare shud be two diles one for the freezer and one for the other thurn the one that has freezer two the rite intell it gets on 5 or wen it gets to max and if its a reguler frige then and it a new one then its in the freezer part if its a older one thin there both in the bottom frige an torwds the roof of the inside if that dont work have your filter cleaned and ask a frigeration company geve you a shot of freeon in it
Dec 16, 2009 | Dishwashers
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge ..you can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Aug 20, 2008 | Danby (DAR604BLS) Refrigerator
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
231 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
