Question about Behringer Bx4500h Ultrabass 450w Bass Amplifier
Behringerbx4500h amp has a bad hum i here the have this problem
How do i fix it
  • Behringer Master
  • 5,603 Answers
If the hum exists with NO input cable plugged in, this requires repair, most likely in a shop familiar with the unit.
The problem may be in the unit's power supply or a broken connection inside.
This problem can also happen if one of the oputput amp transistors shorts driving out DC current into the speaker which is a grave risk to the speaker. Check the DC out of the speaker connector. If it is NOT very near zero, say less than 0.1 volts DC, do NOT copnnect speakers..
Posted on Jul 31, 2010
I have an Fender Rumble 100. I've had it now for about 10 years. When I switch it on it has an loud hum. I don't want to get rid of it, because it been an good amp. What do that sound like the problem to...
I've included a link which provides information on some of the possible causes for hum in an instrument amp. If all else fails to locate the hum, the hum may be caused by a bad filtering capacitor, possibly in the power supply. I suggest you have the amp diagnosed by a reputable musical instrument shop. Troubleshooting Guitar Amplifier Hum eHow
May 26, 2014 | Music
Where to buy TP4T pickup
You can try repair it. They are pretty basic. I would look for poor solder connections, and reflowing all solder joints in it would be prudent.
The hum is likely from a gain stage with a bad solder joint on the input isolation capacitor. Also check other wires and check for bad solder connections on the pickup connections as well. It can even pick up hum through a bad shieid/ground connection in the jack on the guitar
Mar 29, 2012 | Takamine 1 NEW Takamine EG350SC G-Series...
I recently purchased a Fender Classic Player Jaguar Special HH as well as a Fender Super Sonic 22 amplifier. I noticed there is a lot of noise coming from the amp with the jag plugged in, especially on the...
"Noise" is not a very good deescription... is it hum? is it static like? is it a buzz? Hum pickup by the pickups of guitars are common and some pickups are worse. If it is hum move the guitar away from magnetic sources like amps, motors, flourescent lights, dimmers... etc. Sme guitars have grounding problems and touching them varies hum. Also, do NOT let the guitar "hear" the amp as it can feedback at frequencies above your hearing even. Do some "sniffing" by moving the guitar and the orientation around the area seeing if you can find hot spots of noise to avoid.
Sep 20, 2011 | Fender Musical Instruments Corporation...
Humming kind a loud it bothers a lot so anoing.
Unplug the inputs to the amp. If hum disappears, then you need to fix the guitar or the cable or keep the guitar from magnetic fields which are present near amps and other powered equipment. Use of Humbucker pickups helps a lot. If amp has objectionable hum with inouts unplugged, take it in for repair.
May 09, 2011 | SWR 750X Pro Series Bass Amplifier Head...
Just got my fender 63 reverb reissue unit...and when i switch it on all i get is a loud buzzing hum type sound .
If you unplug the guitar cable and STILL get the hum, the unit has a defect... return under warranty.
If the hum goes away when you unplug the cable, replace the cable and see if new cable fixes the problem. If it does, the cable has a bad shield.
If the cable didn't cure it, then the guitar has a defect. Remember that some guitar pickups are sensitive to the magnetic fields from the amps... only cure is to either use humbucker types or be a distance away from the amp.
Jun 29, 2010 | Fender '63 Reverb
I Have the fender 212 soild state amp.When I plug my guitar in to the input.One of two things happen ethier no sound or a hum.I have had this amp in the shop .Had it returned to me and still the same...
You likely have a bad input jack. A VERY common thing with these. They don't like to work on the jack because one has to remove too much to replace it. Lazy shop! Sometimes the solder has just broken loose or the board pads damaged. Replace the jack anyway as they take a beating.
Find a shop willing to work on it properly and DON'T accept it back until it is fixed!
Another problem with amps can be the preamp output jack switch which fails to close leaving the amp dead... but it usually won't hum much when that happens.
HINT: Loop your instrument cord through the handle so when you trip and yank on the cord it won't break the input jack... saves a lot of jack repairs!
Mar 28, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
I have a Fender Telecaster guitar and a Crate amp that cuts out i
The next time it stops, unplug the cable from the guitar and touch the tip of the connector with your finger. If the amp hums, then the amp is still working and the problem is in the guitar. If there is no hum from doing this, then the amp has am intermittent.
Try this before it fails to see what to expect in the way of the hum from this test.
Common problems with the amp are OFTEN with a broken input connector or bad switch on the preamp output jack if it has one.
There are MANY other things and without troubleshooting it is hard to steer you to a fix.
Mar 26, 2010 | Fender '72 Tele Deluxe Electric Guitar
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Mar 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Marshall VS65R is powered up it hums
Blown speaker NO (would not get sound at all)
Bad Reverb UNLIKELY (controls would deselect reverb and it would be out of circuit)
Bad preamp tube NO (controls have no effect)
Bad rectifier and/or filter caps LIKELY
Bad power amp POSSIBLE
Nov 29, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
I have a bad hum in my digetech live 4
you may have a bad cord. try others. all so try reversing the polarity on the back of the amp. DFD
Mar 17, 2009 | Digi-Tech Digitech Vocalist Live 4...
Behringer Bx4500h Ultrabass 450w Bass Amplifier Logo
299 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
