Question about Maytag Atlantis MAV6000 Top Load Washer
I recently had the machine repaired it was not emptying after the rinse cycle. Came and replaced some parts and it worked fine for about 3 days. Now it will not empty after the wash cycle.
    Genius:
  • 1,075 Answers
Under the law you should call back the persion that fixed it and he will do it free of charge.remember you have 12 months warranty with parts and repair.adrian,,,,
Posted on Jul 13, 2010
The agitator on this machine has stopped working though spin and rince cycles work fine. Will replacing the clutch solve this problem and are there any associated parts that should be replaced with the...
if the spin and rinse cycles still work fine then i suspect it might actually be the gearbox which will need repairing/replacing. Be sure to get new seals when you remove the gearbox, unless the seals look in exceptionally good condition.
Jun 26, 2011 | Washing Machines
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer won't fill for rinse cycle on any setting
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Kenmore Washing Machines
Rinse cycle, water won't work
It sounds like you either use warm or hot water for the wash cycle. If this is the case, you probably have a cold water solenoid problem on your water inlet valve (also known as a mixing valve on some washers). Most people use warm or hot water on the wash cycle. The water inlet valve has two solenoids. One for hot and one for cold. It uses a combination of the hot and cold solenoids to make warm water. The rinse cycle on most washers is a cold water rinse only, however. This would explain why the water appears to flow normally when it fills during the wash, and only trickles when it rinses. If you live in an area that has hard water, or if you use well water, these valves commonly clog with sediment. You can shut off the water, remove the hoses, and attempt to clean the sediment screens to see if the water flow improves. If it doesn't, you will need to replace the valve. The following link epxlains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
I know the link says this is for a Kenmore or Whirlpool, but also applies to a Roper. A replacement valve can be ordered on line at searspartsdirect.com. Just type in the model number and the part you need is located under the "Controls and Rear Panel" heading as item number 18 (part #285805). This is a very simple and inexpensive fix if you wish to perform the repairs youself. Not to mention, you can potentially will save hundreds by avoiding the labor charges of a service call. I hope this helps you. If you require additional assistance, please let me know. Hopefully, a good cleaning will do and you won't require parts.
Sep 12, 2008 | Roper RAS8445KQ Top Load Washer
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
Washer Won't Rinse (Hotpoint)
Suggestion: Try cleaning your outlet filter. This needs periodic cleaning, according to your usage. Refer to user's manual re. the cleaning. When it is the rinse problem it usually is the filter block.
Oct 05, 2007 | Washing Machines
Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Oct 04, 2007 | Washing Machines
Error Message coming up
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
Aug 31, 2006 | Meiko FV 40.2 Dishwasher
Maytag Atlantis MAV6000 Top Load Washer Logo
158 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
