Question about HP LaserJet 1320 Printer
My laserjet 1320 (2015d printer) has the paper jam light on and wont work. Have rebooted and turned on and off. what else can i do?
  • imnancee379 Jul 13, 2010
    I have the HP laserjet 2015d. the paper jam light remains steady so i cant use the printer. I have rebooted the printer. I also would reboot holding the "go" button. I have pulled out the paper tray to see if there was a blockage. no. i pulled out the toner as well as opening up the straight-path output and nothing is there. what can i do?
    President:
  • 567 Answers
Hi there you need to open the printer and take out the paper that is stuck up inside the printer and reboot the printer and it should be alright.
Posted on Jul 13, 2010
    i ave taken everything out to get to the guts of the printer. there is no paper in the printer.
  • Hilton Bristol Jul 13, 2010
    Thanks for replying, since there is nothing stick up in the printer the next solution is: you should take is to uninstall and reinstall the drivers for the printer,then restart printer and try to print from it.
  • HP Master
  • 6,826 Answers
OK.
Did you remove all traces of paper by opening the lid and checking?
Sometimes, paper can rip off and still be lodged inside the rollers of the printer causing this error.
May have to disassemble the toner cartridges to look inside.
Also, remove the paper tray(s) and look inside for paper that has been partially pulled into the printer.
Wish you luck on this one.
    i have taken the papertray and cartridge out. i see nothing there to jam the printer. When i press the Green "go" button nothing happens. When i turn on the printer it does not cycle thru the lights like it should. Automatically has steady yellow light on paper jam.
  • Duane Wong
    Duane Wong Jul 13, 2010
    Follow this link to hp's paper unjamming page. It's kind of too long to post here so:
    http://h20000.www2.hp.com/bizsupport/Tec...
    Hope that clarifies things a little.
    If you can't fix it by following the diagrams and steps provided there, it may need professional service by an authorized hp service center.
Paper jam in tray 1
Take the paper tray out and check if the paper is sticking. Refill the tray and try it again. My Canon makes a loud clacking noise when it is 'spooling" a new tray full of paper until it loads a new sheet.
Dec 27, 2017 | HP Color Laserjet Cp2025 Printer Laserjet...
PC communicates with my HP laserjet 1020 but paper does not seem to pull through and wont print and orange fault light flashes then stays on
nothibg to warry about it just check tonner if its ok then do the servicing and also see for the paper jam chek may be ther e inside paper was jamed yeterday
Jun 07, 2012 | HP LaserJet 1020 Printer
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Cheers!
-a.
Apr 10, 2012 | HP LaserJet P2015dn Printer
Hp laserjet 2015 printer shows an indicator light error that theres a paper jam but actually no paper jam or paper particles . I have cleaned aii the sensors and checked the paper path. Powers on well...
restart it
if problems insist check if sensors are working
if are working you need to replace motherboard
of your printer that cost to high
you better replace your printer
hope i had help you
Nov 26, 2010 | HP LaserJet P2015 Printer
My HP CP2025 printer says it has a paper jam even after we removed the paper. I've turned it off, unplugged it, and still says paper jam when re-started. i'm not sure what else to try.
This could be because one of the sensors was damaged by the paper jam.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If this doesn't work it could be a hardware failure and will require service (it's either the formatter or the dc controller)
Al
Eliteprintersolutions@gmail.com
Nov 11, 2009 | HP Laserjet Cp2025n Printer
Orange light is flashing
I cleaned out the printer by removing any access toner. Made sure again no paper was stuck and then it worked.
Apr 14, 2009 | HP LaserJet 2100 Printer
Printer wont work
try to remove cartridge and look down in to printer, use flash-light or lamp to find. Also chek fuser unit ( exit unit) from paper.
Mar 03, 2009 | HP LaserJet 3015 All-In-One Printer
Will not print after pulling forward a jammed paper
make sure the paper didn't tear and a peace got jammed somewhere in there. then reset the printer.
Feb 09, 2009 | HP LaserJet 1200n Printer
HP Laserjet 3050 No paper pickup
My printer now spits out the paper all over the place and jams up all the time. Did not happen when I first got my 3050 a few months ago.
Jun 06, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 1320 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
