Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
The dishwasher will start washing and then quit running. It will continue to say that it is washing but nothing is happening.
  • 250 Answers
It sounds like the motor is overheating. If something like a bearing is wearing out, it would be better to leave this to a professional. However, there's a couple things you can try. Turn off the power and water connection to the dishwasher, and remove/lift up the panel below the door. Make sure there is not any dust or anything blocking ventilation to the motor. The dishwasher may not be level, putting stress on the motor. It may be necessary to pull out the dishwasher, if connections permit, and place a level on top of it. Turn the bolts that make up the feet to adjust the height of each corner. Be careful not to break the water line or snag the electrical wires. Turn off the power and water to make sure you don't get a shock or flood.
Posted on Jul 13, 2010
2 Suggested Answers
  • 8 Answers
SOURCE: the dishwash is not washing, it's running but
Sounds like a bad water valve or the water supply is cut off. If the water supply is not cut off then try hooking up 120 volts to the water valve. It should buzz or hum and let water in. If no water goes in then change the valve.
Posted on May 15, 2010
New dishwasher won't wash
What noise does it make?
Jun 09, 2013 | Dishwashers
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
Dishwasher won't start
may be in flood mode. tip the unit sideways and see if water leaks from the base if so continue to tip it until it all drains out, then start it on a wash if it starts you have a component leak that will have to be sourced.
Mar 14, 2009 | Dishwashers
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Fisher Paykel 2 drawer dishwasher
When it sticks like this, does it continue to wash or does it stop?
Nov 27, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
KENMORE ULTRA WASH 1626
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Nov 27, 2006 | Kenmore 24 in. 16262 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
122 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
