Question about Canon Cameras
Camera filter stuck on lenses
Polerizer is stock on lens
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
You can try using one of those rubber jar openers, if you have one handy in your kitchen. Or wrap a suitable size rubber band around the filter to improve traction.
If that doesn't do it, a good camera store should have a filter wrench for exactly this purpose. If you don't want to buy one, simply ask for a demonstration of the product, using your lens. Most clerks will be happy to remove one or two filters. If you bring in a large box of lenses...
Posted on Jul 23, 2010
Testimonial: "I was told this buy a club member also. i used a pair of rubber work gloves to work it loose. thanks the camera store was next on my list. "
What lense can i use for close-up shots
That would depend on the camera, but I'm going to assume you have one with interchangeable lenses.
The camera manufacturer probably makes one or more "macro" or "close-up" lenses for your camera. Any of these lenses will let you get closer than a normal lens. Many third-party lens makers also make macro lenses.
Another alternative is to put extension tubes between the lens and the camera body. This moves the lens further from the camera, shortening the focus distance.
Probably the cheapest (and lowest quality) alternative is to put close-up lenses on the front of any lenses you already own. These screw on to the front of the lens like a filter and act like a magnifying lens, letting you get closer to the subject.
Sep 07, 2013 | Computers & Internet
Just bought the Olympus pen EP-L1 Im having trouble find lenses for my new toy any suggestions?
You don't state why you're having trouble finding the correct lenses, but they are easily available from online suppliers. Traditional retail outlets tend to stock very few of them though simply because there isn't sufficient demand to buy in and keep stocks of products which are constantly having updates and price adjustments.
You can use all Olympus Micro Four-Thirds lenses and most Panasonic Micro Four-Thirds (although to use some of the latter you may need to update the body or lens firmware.
Regular Four-Thirds mount lenses can also be used via an adapter but may not be fully functional.
Unlike other lens mounting systems, you can also get adapters to use almost any lens on Micro Four-Thirds system cameras, but the lens will typically have to be used in a fully manual mode with the aperture set fully open for composition and focus and then manually stopped down for metering and image capture.
Jul 12, 2011 | Cameras
Lense stuck out camera shuts downwith lense out
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 21, 2010 | Kodak EASYSHARE M1063 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Zooming lens got stuck up
The lens need to be replaced and is failing I have new lenses in stock if you need more information go to www.digitalcamrepair.com.
Mar 02, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Lens filters
Lee, a little rubbing alcohol dabbed around the seam between the filters should loosen the threads, Make a full circle and while they are damp, tap the filters lightly a couple of times and try to separate them
Jan 28, 2008 | Sakar DIGITAL CONCEPTS FK49CL Camera Lens...
Lenses
Your camera's problem is with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 15, 2007 | Canon PowerShot SD850 IS Digital Camera
Conversion lenses
Product Description Stock # List Price Notes M-CON 40 (Close-up Lens) 200 713 $164.95 *Step-up ring (43-55mm) included. WCON 0.7x Wide Angle Lens 200 864 $139.99 Requires 43-55mm step-up ring TCON 1.7x Tele converter Lens 200 862 $129.99 Requires 43-55mm step-up ring
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Conversion lenses
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Cameras Logo
217 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
